Question about Jensen VM9510 Car DVD Player
Tview d62tsb touch screen will not let me play my subwoofer
Tview touch screen will not let me play my subwoofer from amp.
What does this mean on my D93TSG screen?
That looks like a lock screen pattern like you do on a Samsung cellphone. Do it once, (your screen), do it a second time to confirm. That is your pattern to unlock in future.
It says there is an installation video here
http://www.qualitymobilevideo.com/d93tsg.html#.WO15W6K1vIU
D93TSG Google Search Tview D93TSG Single DIN In Dash 9 3 Inch Wide Motorized Touch Screen...
Apr 12, 2017 | Computers & Internet
Plays video then goes to black screen.
If everything is installed correctly, front and rear viewing may be available only with your vehicle not in motion. Only rear viewing may be available in notion. It's a safety issue.
Apr 08, 2014 | Tview T102SVBK 10.2 inch sun visor monitor...
Screen wont work on my tview d74ts in-dash touch screen
Is it wired correctly? Red wire to switched ignition accesory, such as the factory radio was? Yellow to battery? Are their fuses intact?
How about the ground wire? Or did you just secure that to the dash? If so, that metal piece may not have a ground connection to the body shell, or the engine.
Jun 01, 2012 | Car Audio & Video
When I put my DVD into my Tview headrest unit, it runs and runs and runs and then comes up and says no disc
If that only happens with one specific DVD, the problem is that DVD. Try playing it on another DVD player and see what happens.
If your TView won't play any DVDs, try turning the power off, blowing some compressed air into the unit, and turning the power back and see if that makes a difference.
Jul 01, 2010 | T-View TView (DVD1006) In-dash DVD Player...
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
Tview t104fdsh overhead monitor plays picture upside down
There should be a section in the set up of the monitor to invert the screen. or maybe a invert button/reset
Mar 11, 2009 | T-View T1045IR 10.4 in. Car Monitor
Burnt amp
inorder for it to blow out either there are two wires touching or it isn't properly grounded or it is faulty. if it is faulty you need to use the warranty(if it isn't too late) and get an new one
Jan 30, 2009 | Infinity BASSLINK Car Subwoofer
Wiring
1st make sure your amp is coming on. Use another speaker that you have heard play to test it.
Next test the woofer with a 9 to 15 volt battery. Touch the battery leads quickly across the + and - on one side at a time. The speaker should move and make a pop on both voice coils.
If the amp plays and speakers play, then you need to know the power rating and impedence stability of both amp and speakers. That will determine how they are wired up.
Jul 28, 2008 | Digital Audio DA8012 12" Subwoofer Car...
Jensen VM9510 Car DVD Player Logo
22 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
