Question about Panasonic Viera Tc-p42x5 42" Inch Flat Panel 720p Plasma Hdtv Television
Tv will not turn on
The breaker kicked off and now the tv will not turn on
Samsung tv lightning strike reset
It is likely the ac fuse which the power cord goes directly to got hit.
back would have to be removed and fuse checked.
Mar 18, 2012 | Samsung Televison & Video
Main breaker keeps kicking, yesterday it effected the dryer, washer and lighting! Turn dryer on and lights worked, turn it off and lights would go out! Washer wouldn't run at all. Thought the house was...
I would be inclined to think the main breaker is almost worn out and needs replaced very soon.If it's taking out the main instead of individual breakers I would get a good electrician on it right quick. Good luck and thank you.
Feb 21, 2011 | Electrical Supplies
The hottub keeps kicking the circuit breaker off.
Either the breaker is bad or you have an electrical problem. Unless you know how to work with electrical problems call for service. If you unplug the hot tub and plug a lamp or hair dryer into the outlet does the breaker trip? If yes, call an electrician. If the outlet is fine call for service on the hot tub.
May 01, 2010 | Home
GE Profile Model#DPSB513EBOWW Breaker kicked to
Have you reset the dryer breaker also. Even if doesn't look tripped turn off then back on again.
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
We have arc fault breakers on our house built in 2002. in trying to plug in our 40'' lcd tv the breaker kicks out as soon as the plug touches the outlet. We've even tried brand new high end TrippLite surge...
Well, considering all TV's these days have what is called a SMPS which means Switch Mode Power Supply. As soon as your plug enters the outlet it will ark, because the power supply starts up immediately, so my suggestion would be is to kill the breaker to that room then plug the set in and then reset the breaker. Let me know how it turns out.
Oct 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My RC air conditioner (Duotherm) kicks the circuit breaker every time I turn it on. It used to kick the circuit breaker every so often, but lately it kicks it immediately if I try to turn on the AC.
Try replaceing the start or run capacitor to the compressor. If no help you can install a start assist capacitor, it helps to start a tight compressor.
Sep 10, 2009 | Dometic Rooftop RV Air Conditioner
Dishwasher wont turn on
The dishwasher is generally on a separate circuit so if that circuit breaker kicks, or that fuse blows you won't see anything else turned off. Go to you panel and check to see.. If it is a blown fuse, replace it with a new one of the same amperage. If it is a kicked circuit breaker turn the breaker all the way off and then back on.
Apr 07, 2009 | GE GSD3800G - Multiple Color Built-in...
Kicks off circuit breaker
make sure your breaker is high in amps, at less 50 amp breaker
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Panasonic Viera Tc-p42x5 42" Inch Flat Panel 720p Plasma Hdtv Television Logo
376 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Nagendra Baliga
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
