Question about Envision H190L Monitor
Take off stand on envision monitor
How to remove stand
    Novelist:
  • 242 Answers
Look on the back for four screws that hold it on they should be in a square pattern which is the VESA standard.
Posted on Apr 10, 2015
3 Suggested Answers
SOURCE: ENVISION EN-985E MONITOR PROBLEM
When using this monitor on a PC running Windows Vista Home Premium the screen text is blurry and hard to read . I have tried working with the Clear Type in Vista and that does not help . I have reloaded the driver for this monitor and this did not help either . Any suggestions ?
Steve
Posted on Dec 08, 2007
SOURCE: remove base completely from envision monitor
after removing all the screws, i used a knife to remove the plastic casing surrounding the monitor. that exposed four screws that when removed, released the base from the monitor. it was just a matter of putting the casing back together. thanks
Posted on Jan 31, 2009
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
Jan 18, 2014 | AOC 24 Envision L24H898 1080p Widescreen...
Need to remove monitor stand
should be four screws holding it on. Take them off and keep them safe. The monitor is made to take this off and mount to a VESA square block plate for wall-mount etc.. look and you will see them there.
Dec 29, 2013 | Envision EN7410 17" LCD Monitor
How do you take the base stand off of an envision 22in lcd tv? I want to mount it to the wall?
There is a screw on the part of the base where it connects to the monitor back, it is located on the pivoting arm, remove or take loose this screw and lift the base by holding the side opposite the screw. the base should lift off with at very most just a bit of wiggling. You can now use the wall mounting screw holes located under the corners of the sticker on the rear of the monitor, they are usually covered with a perforated area.
Jan 16, 2011 | Envision H22W 22" Monitor
How do you take the base of a envision H170L
Can't find too much info on this monitor. Look for a crease/gap in the plastic around the neck of the stand. Most likely a plastic cover is covering the screws you need to unscrew. You'll probably just have to pop it off.
You may have to first remove the flat part of the base (if looks like it separates from the neck). Check the bottom of the base for tabs or plastic clips holding it to the neck. If the flat part of the base doesn't come off, just look for the plastic covers mentioned above to reveal the screws that are holding the base on.
Jan 12, 2010 | Envision H170L Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Remove base completely from envision monitor
Jan 30, 2009 | Envision 19" Widescreen Flat Panel LCD...
AOC lm929 monitor
AOC LM929 or Envision EN-7100 removal instructions:
DANGER!!! UNPLUG and allow the monitor to discharge before servicing.
with a small flat head screwdriver, insert into the edge and pop open the small plastic
pieces that surround where the stand connects to the monitor. put plastic pieces aside.
lay monitor on soft flat surface front side DOWN. with a phillips head screwdriver,
remove 4 screws in the center that hold on the stand. put stand and screws aside.
lay monitor on soft flat surface front side UP. insert flat head screwdriver into the
side edge of the grey plastic and turn screw driver so the plastic surrounding the
screen edge pops up exposing an area surrounding the screen. put plastic rectangle
piece aside.
slide out plastic buttons piece from the side and put aside.
with a phillips head screwdriver, remove 8 screws (4 on top and 4 on bottom) that hold
the screen assembly to the back housing. now lift screen assembly out of the plastic
housing. put back plastic housing and screws aside AND lay the monitor screen with the
FRONT side down on a flat soft surface.
with a phillips head screwdriver, remove 2 screws that hold on the metal electronics
cover. slide the cover down and remove. put the cover and screws aside.
USE CAUTION!!! Some components may still contain a charge.
check fuse... whatever...
Aug 29, 2008 | Computers & Internet
Steve
Dec 05, 2007 | Envision EN-985e Monitor
Envision H190L Monitor Logo
119 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
castletech
castletech
Jim Goldsmith
Jim Goldsmith
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
