Question about Pool & Spa
Dearborn Heater Manuals - Pool & Spa
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
How do i convert my dearborn gas heater to propane
There is a pilot, burner orfice spuds, and a gas valve pressure regulator spring that comes in a conversion kit that you will need. It will come with instructions. Google the manufacturer for a dealer near you. Hope this helps.
Oct 01, 2014 | Water Heaters
Have a dearborn ventless natural gas heater that is probably 100 years old that has been used every winter here recently i am getting a fummy odor from it i have cleaned gas valve raidants and burners did...
I t sound to me as if the heat exchanger is beginning to fail. do you have carbon monoxide detectors? If not please get some. Having the unit inspected by the gas company will not hurt.While specking with the gas company ask if the have added different oderants to the gas supply. Please play it safe with this guy and have the inspection.
Feb 10, 2011 | Heating & Cooling
How to light the pilot on a dearborn room heater
Turn the knob to PILOT. press the knob down. Light the pilot and hold the knob till the pilot stays lit by itself. Then advance the knob to the ON position. Turn up the thermostat.
Jan 02, 2010 | Heating & Cooling
Can't raise flame level
Obviously, if you read my post, I DIDN'T solve the problem because the problem WASN'T with a PRINTER but with a HEATER. I know that there are Dearborn heaters all over the place, but for some reason your site doesn't want to address them.
Feb 04, 2009 | Citizen...
Hi 1962 Ford Galaxie Convertible 390cid V8 Need the Left side Exterior Chrome Strips(2)narrow and wide. How to locate the part on the internet? Thanks kondean@yahoo.ca PS: Galaxie not listed below....used...
Check with Dearborn Classics. They're out of Bend, Ore. Google 62 Ford Galaxie and check the related links. Dearborn Classics deals with Ford parts and are very good. They have alot of information on the early iron Ford parts.
Jul 15, 2008 | Ford F Cars & Trucks
Pool & Spa Logo
142 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
