Question about Bose LifeStyle 5 Series-III CD Shelf System
Can i replace a 33uf 25v with a 100uf 63v - Bose LifeStyle 5 Series-III CD Shelf System
    Top Expert:
  • Bose Master
  • 43,901 Answers
Not a good idea. You may create other problems.
Posted on Nov 17, 2013
Teac ct m685 shutting down
Removed and checked the power supply unit and confirmed the capacitors
C905 220uF 420V was measured at 200uF
C926 22uF 160V measured at 21.6 uF
C908 10 uF 100V measured at 10.35 uF
C910 47 uF 63V measured at 45.8 uF
Resoldered all of the joints on this PCB to ensure good connections.
On the Main PCB checked capacitors
C401 220uF 35V measured 214 uF
C417 100uF 160V measured 100 uF
C411 3300uF 35V measured 3090 uF
D204 was still a diode
C430 4.7nF 1600V measured 4.5 nF
C406 4700uF 25V measured 4460 uF
Reassembled and confirmed worked OK
These checks / repairs did fix this fault and the television is running well.
Dec 29, 2012 | Televison & Video
My acoustic solutions tv turns itself off every time i switch it on, what could be the cause
It may be detecting shorted circuits in the power supply, backlight inverter boards, main board. You need to troubleshoot the problem starting at the power supply module first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 09, 2010 | Televison & Video
Bose lifestyle 5. Display is erratic when playing cd or radio.
Change capacitor C19 (33uF 63v) next to the dispaly. This capacitor goes leaky over time, and causes ripple on the display which makes it dim or even dissapear completley. Also worth doing all the capacitors near to C19 while your there just in case.
changing C19 worked for me. Some people even up rate the capacitor to 100v, but 63v id the manufacturers reccomended.
Aug 23, 2010 | Audio Players & Recorders
Everything works with my bose lifestyle model 5 music center but the display wont light up. Do I have a bulb out or something ? How can I fix this, its driving me nuts! Thanks for any help you can give....
According to other threads this is due to a bad capacitor (either C19 or C16). It is a 33uF capacitor rated at 25V. Needs to be replaced by a 33uF higher voltage (like 63V). Have the same issue but have not yet completed the fix. Please perform a search on the forum and you will find it. It says is on the lower left side of the console pcb.
Dec 20, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
When i switch on my P.C. and my FP 5313 screen it flickers
This is a known problem with a series of components inside the monitor. There are about 11 capacitors that if replaced will allow the monitor to function properly.
The best place to go to read more is http://www.badcaps.net/forum/printthread.php?t=2658
The list of the capacitors that are bad are below with possible replacements.
C922, C925: Hermei LE 1000uF 16V, low impedance, general purpose, replacing with 1000uF 16V Samxon GF.
C201: Hermei LZ 150uF 25V, ultra low impedance, high ripple current, replacing with 1000uF 25V Samxon GF.
C924, C926, C929, C930, C932, C933: Hermei LT 470uF 16V, high ripple current, low impedance, replacing with 1000uF 16V Samxon GF.
C207: Unknown CD110 50uF 4.7uF (general purpose), replacing with a 35V 4.7uF tantalum unit (SCP/Short Circuit Protection pin on TL1451 won't get anywhere near 35V).
C907: WC (with stylized Westinghouse W) SM 22uF 50V (general purpose), replacing with 63V 100uF Samxon GF (used for SMPS controller Vcc filtering).
C905: Hermei HT 100uF 400V, standard, general purpose, leaving as is - generally no problem.
Dec 06, 2008 | HP Compaq FP5315 15" LCD Monitor
Bose Lifestyle 5
Changing the capacitance value (33uF) is generally not recommended. As for the voltage, you can always replace a lower voltage cap with a higher voltage as long as it will physically fit.
Dec 13, 2017 | Bose LifeStyle 5 Series-III CD Shelf...
Help - I have the same Fault!
Normally DC BUS FAULT is fixed by replacing C14 and C10. C14 is the 100uf/63V and C10 is 2200uf/16V. They are located between the heat dissipator and the logic board near transformer TX1.
Mar 12, 2008 | Powerware 9120 UPS System
Zenith a27a11d
possibly c3416 100uf 25v and c3413 22uf 63v capacitors in the power supply or replace the module if you can get one part number is 9-1791-01
Nov 26, 2007 | Zenith A27A11D 27" TV
Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Aug 16, 2007 | Bose Lifestyle 12 System
Won't turn on
Hello, please check +/- input capacitors 2052,2068 and 2071. Replace Diode 6307 (BY229X600). Also replace 2055 100uf/50V with 100uf/63V Best regards, Arpi
Jun 23, 2007 | Philips 50P8341 50" Rear Projection...
Bose LifeStyle 5 Series-III CD Shelf System Logo
82 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
