Question about Panasonic TH-C42HD18 42 in. Plasma TV
HDMI remains black and no sound
No pic or sound from HDMI only from rca jacks work. Can anyone help?
Change the source select on tv to hdmi
Posted on Nov 17, 2013
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
I have a Phillips plasma tv model number 42PF5521D/10 serial number VN4B0708013071 i was watching it on 1 of the 2 hdmi channels when all of a sudden it just went off when I turned it back on all I had was...
Does it work on the cable/antenna input jack? Can you get the menu screen to show up? If none of the inputs work and you can't get a menu screen to show up, then it sounds like you may have a bad YSUS driver board.
Mar 21, 2014 | Televison & Video
Dynex blu ray sound and no picture
try a new HDMI or try compusite cables they are five cables green blue red white and black or you could try just rca jacks yellow white and black the only problem with rca jacks is it wont be HD but you will have sound and picture
Dec 09, 2012 | Dynex Blu Ray Player
Sound and rca jacks not working on rca 46 inch lcd tv
check ur set up find manual if no go .go to there web site
Aug 12, 2012 | Televison & Video
Just bought a samsung plasma hd tv. we are able to get satelite w/ sound but once we try to connect to the dvd/ vcr and playstation 2, we are unable to get sound or it shows up in black and white.need step...
Hi,here is my solution...
to listen your TV on your
stereo System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
stereo Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Samsung Televison & Video
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
Motorola DSR505 HDMI problem
Check to see if input 5 has a audio in source via RCA jacks. Many times manufactures will give you multi HDMI inputs but only one that has RCA jacks in case you are running a DVI/HDMI cable. If input 5 does not have those RCA jacks you will not have sound. I know this unit has multiple HDMI inputs. Look to see if any of the other HDMI inputs also have RCA jacks.
I hope this helps,
Skyassoc
Jun 22, 2009 | Televison & Video
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Panasonic TH-C42HD18 42 in. Plasma TV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
