Question about Video Game Consoles & Games
My ps3 won't connect to Internet cannot find ip address it says
    Habit-Forming:
  • 38 Answers
Turn off your PS3 then turn off router. Turn router back on, wait 3 minutes then turn on PS3.
Posted on Nov 17, 2013
WhIzAtIt
  • 136 Answers
SOURCE: connecting to the Internet
Turn off the PS3, unplug the power to the cable modem, let them sit 5 mins. Plug in the power to the cable modem ONLY, wait for all lights to be on steady except for the activity light Then turn on the PS3 and check the network IP addy.
Posted on Sep 15, 2007
jeesusfreek
  • 18 Answers
SOURCE: PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Posted on Feb 01, 2008
SOURCE: Internet connection failed but IP address obtained.
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
Posted on Jun 07, 2008
  • 400 Answers
SOURCE: ip address
change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
Posted on Jun 23, 2009
SOURCE: PS3 connection problems
error code is 80710102 when trying to log in.
Posted on Jun 30, 2009
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
Oct 12, 2016 | Sony Playstation 3 (PS3) Console
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Won't connect to internet , can't find ip
ITs looking for your pcs router ip address.
Start your pc, type cmd in run box.
Small black box will come up.Type ipconfig in this box.Hit enter.
Your ip address should be listed there. enter it in your ps3.
Jan 11, 2010 | Sony Playstation 3 (PS3) Console
PS3 Internet Connectivity Problem - 80028E01
Restore your router to factory settings, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
HELP?
Restore PS3 to factory settings and change your network settings:
Best Results: Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
Also check your cable connections.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 sharing an ip address
it's something with your router. try assinging static ip addresses. that'll fix it. or contact your router manufactere and ask about DHCP and figure out that way why your router is assigning everthing the same ip address
Mar 29, 2009 | Sony Playstation 3 (PS3) Console
Ip and proxy error
well, if you know how to setup the ip addresses manually both on your modem / router and on the ps3 i recommend you do that... but bear in mind that your dhcp server (on your modem / router) should prohibit automatic assignment of that same ip address with your ps3... for that you have to specify a range of automatically assignable ip addresses apart from your ps3...
if you have the dmz (demilitarized zone) option on your modem / router, set it up for the ip address of your ps3, which you've setup manually...
example:
router ip: 192.168.2.1
ps3 ip: 192.168.2.10
ip address pool: 192.168.2.100 - 192.168.2.250 (this shpould be manually setup not to interfere with the fixed ip address of the ps3)
dmz host: 192.168.2.10 (ip address of the ps3, which enables "opens" all of the ports for this ip address)
apart from that if you use any proxy servers to connect to the net, you have to specify these in ps3 settings as well...
there are a lot of threads on various forums on how to tweak your network connection to optimize for ps3...
i hope this solves your problem...
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
