Question about Gigabyte GA-Z87X-UD3H Z87 Motherboard and Intel Core i5-4670K Process
Jack plugged in but there is no jack
Windows (and Linux too) shows me that a jack is being plugged in and out constantly. Is it a hardware malfunction? Shoul I have my board replaced?
    Brigadier General:
  • Gigabyte Master
  • 3,400 Answers
DETAILS,EUGENE.
Posted on Nov 17, 2013
Headphone port does not work on acer aspire 5250
Click Start, Go to control panel, then Hardware and Sound, then Sound. Click "manage audio devices". Plug in your headphones and see if they show up.
If they don't, your divers are missing or the the headphone jack is broken or clogged. The most common reason they don't show up is actually gunk in the jack, so make sure it's clean with a bright flashlight and use a toothpick or something similar to clean it out.
If they don't show up and your jack is clean, use windows update (it will detect many of your missing drivers) or go to acer.com, click on support, drivers, and enter your model number and download the audio driver and install it.
If you DO see the headphones show up as an audio device. Then just set them as default (by clicking "set as default") and it will work.
Hope this helps!
Sep 21, 2013 | Computers & Internet
Tip
What do i need to program a speakercraft mzc64, mzc66, mzc88 ?
This info is meant for all the Speakercraft MZC controllers.
The software used to program the mzc controllers is called EZ TOOLS the latest version of which is 401. This version handles both the IR database versions released in these units.
V313 is the older one and 401 is the latter.
you will need a laptop which runs windows, EZ tools is native to XP but should work emulated under later versions of windows. I have this running on linux under wine with some basic command line mods to allow the com port to be seen by wine, this works well although some of the rendering of graphics looks incorrect but still good enough to use.
You also need a cable with a female 9 pin d sub at one end and a stereo 3.5mm jack plug at the other, use screened cable.
The correct port to use on the back of the mzc is the jack com port not the dsub rs232 port.
There is no way to copy theprogram off a machine, you have to either have the origion project file that works in ez tools or start from scratch with a new file.
If you need to transfer from one mzc to another one if the first mzc unit has failed hardware, you can remove the rom chip which is plugged into the control board located behind the front panel. This can be swapped over to the other mzc and is the identity of the mzc controller.
For making up a communication cable use the following pins..
Pin2 dsub to tip of jack
Pin3 dsub to ring of jack
Pin5 dsub to earth jack
Trust this info helps.
on Feb 28, 2015 | SpeakerCraft MZC-66 6-Zone 6-Source...
Dell 546 desk top. No audio from external speakers. Downloaded driver. No help. Any ideas?
If you are using Windows, try going in the the Device or Hardware manager and removing the device. Then, look on the menu bar at the top to rescan for hardware changes. Sometimes this is the best option. I am assuming that the speakers work, but, I would plug in a set of headphones to be sure. Also, sounds dumb, but ensure that you are not plugging the speakers into the mic jack (microphone) or the line-out jack (low level output) instead of the headphone jack.
Nov 05, 2011 | Dell Inspiron 546 MT PC Desktop
No sound
Please install / re install the driver and check back the sound.
Regards, Jay
Feb 26, 2011 | Computers & Internet
Can i connect ethernet cable to my 6 years old packard bell desktop
As your Laptop itself doesn't have a ethernet card, you can't connect it. But I have a solution, you can buy a USB Ethernet Adapter, which you can buy for a cheap price and you won't need to open up your laptop or any stuff like that. Just plug into your USB port and start working with Ethernet.
It looks like this:
Hope this helps.
Apr 17, 2010 | Packard Bell Easy One Silver 2101 Notebook
Windows 7 cant hear 5.1 surround sound through laptop audio jack
Are you sure that the soundcard supports 5.1 on your laptop?
Dec 13, 2009 | Computers & Internet
Headphone jack does not work, audio still plays from speakers
sound like the hardware supporting your headphones may have disconnected from its solder.This could have happened from dropping the notebook with the headphones plugged in and landing badly, or a strong or constant tug on the input. Otherwise, it could be a software configuration like you've tried
Jun 08, 2009 | HP EliteBook 6930p Notebook PC
I have acer aspire one(linux) when i was installing windows i got blank
are you trying to replace linux with windows
you need to make sure you have AC power jack plugged in
Feb 03, 2009 | Computers & Internet
No response to my microphone
1st try to check if the driver of your sound card is properly  installed in your operating system, if youre using windows it will be on the device manager 2nd if it is installed or its not showing then 90% would be a hardware problem on your sound card or the jack itself
Sep 18, 2008 | ASUS A7V400-MX Motherboard
Aspire 3680-2574 Headphone jack
right click my computer--> properties-->hardware-->device manager-->sound devices-->find realtek hd audio-->right click-->disable-->OK
wait at least 3 min
repeat and enable
Oct 09, 2007 | Computers & Internet
Gigabyte GA-Z87X-UD3H Z87 Motherboard and Intel Core i5-4670K Process Logo
48 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
