Question about Viva Media Ankh: Reverse The Curse
Ankh Reverse the Curse won't run on windows 7
I can't run "Curse: The Eye Of Isis" in Windows Vista - any hope ???
I have a "virtual" copy of Windows running on my computer at home that use for running older games and applications. There are several free programs out there... Microsoft has one: Virtual PC and there is a Open Source version hosted by Oracle: www.virtualbox.org With a dual-core or higher, 2GB or greater RAM, you can run a virtual desktop with ease... All you'll need is a old copy of Windows to install (e.g. Windows XP, Windows 2000, Windows 98)
Nov 15, 2011 | DreamCatcher Interactive Curse: The Eye Of...
Recently had windows seven installed after a burn out on old hard drive not compatible with my scanner kv-s1025c any help please
Hello, basically, that's the curse of Windows 7. Unless the manufacturer of the peripherals is prepared to support the older stuff by writing new drivers for it, (and, of course, he won't make any money from that!) there's nothing we can do except shell out for new stuff that IS supported under W7. Personally, I'm sticking to XP Pro, as it's never let me down and there's bags of life in it yet. Regards, nicam49
Sep 06, 2011 | Panasonic KV-S1025C
I have Curse: The eye of Isis, and it dosnt work on my windows 7/ home premium. Is there any patch I can get?
DreamCatcher no longer lists this game at their site: http://www.dreamcatchergames.com/dci/pc.php . So there are no patches available in the support site.
Curse: The Eye of Isis was issued for XP and older versions of Windows. The installers and drivers are totally different with Windows 7. What version of Windows 7 Home Premium do you have? If you have the 32-bit version, the compatibility mode might work. (It is less likely to work with 64-bit Windows 7. However, there are no guarantees for either version.)
To try using the compatibility mode: right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Make sure the program is running in the compatibility mode if it does install by doing the right click and Properties step again.
A method that will work but will cost more money is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you buy an upgrade to Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
Apr 04, 2011 | DreamCatcher Interactive Curse: The Eye Of...
Rahjongg the curse of ra will not install in windows 7 can you please help me
Right click on the setup icon file and click on run as admin or run the set up file in compatibility mode select windows xp.
Mar 13, 2011 | eGames Rahjongg: The Curse of Ra for...
How can I run my old copy of Monopoly from Infogrames on Windows 7?
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
Feb 13, 2011 | Infogrames Monopoly 3 for Windows
I have Mahjongg variety pack. I was using windows xp. I now have Vista. It will not play on vista.
I just installed it tonight. (Yes, I have Vista.) Two of the games work great. All I did was right click the icon that was on my desktop (I made copies and put them on my desktop - the program didn't do this), clicked on properties, clicked on the tab called "compatibility", checked the box that said, "Run this program in compatibility mode for", and from the dropdown list, I chose Windows 98/Windows Me. Also, I had to temporarily disable Avast, and turn off "real time protection" on Microsoft Security Essential (I turned it back on after the games were installed.).
The games that work for me are Mahjongg Empire and Mahjongg Master 3. Rahjongg the Curse of Ra is being obnoxious (I came on here to find a solution) and the other one won't do anything, not even install. Anyway, I hope this helps you get at least the first two games installed.
Aug 26, 2010 | eGames Rahjongg: The Curse of Ra for...
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
I am on level 12 in the game and can't compelted can you help?
well if u can complete it dont give up just keep trying sooner or later u will win.i know cuz thats wat happen to me and i kept trying and i won
Sep 15, 2009 | eGames Rahjongg: The Curse of Ra for...
Open Questions:
Big Box of 700,00 Games This is message I am getting on several games I cannot open: See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ComponentModel.Win32Exception: The directory name is invalid at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo) at System.Diagnostics.Process.Start() at System.Diagnostics.Process.Start(ProcessStartInfo startInfo) at LauncherVS.Launcher.spawnGame(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- SPG Games Launcher Assembly Version: 1.0.4903.27476 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/700,000%20Games/Game%20Collection%20700,000/Launcher.exe ---------------------------------------- msvcm90 Assembly Version: 9.0.30729.6161 Win32 Version: 9.00.30729.6161 CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Feb 26, 2017 | Viva Media Video Game Consoles & Games
Viva Media Ankh: Reverse The Curse Logo
Top Viva Media Video Game Consoles & Games Experts
k24674
ray gallant
Are you a Viva Media Video Game Console and Game Expert? Answer questions, earn points and help others
