Question about AGPtek 8X LightScribe DVD RW Burner Drive For HP G60 G61 G70 G71 HP Pavilion dv3 dv5 dv7 DVDRW Burner
Lightscribe not recognizing drive. - AGPtek 8X LightScribe DVD RW Burner Drive For HP G60 G61 G70 G71 HP Pavilion dv3 dv5 dv7 DVDRW Burner
My computer does not recognize my hp 557s as a lightscribe compatible device
Hi professa31!
Have you tried installing the Lightscribe software bundle? Their website says that it's required for operation of any lightscribe device. Here's the link: http://www.lightscribe.com/downloadsection/windows/index.aspx?id=810
Also, it appears that there are a bunch of reasons why it may not be detected, most of which are not bad at all. Here (http://www.lightscribe.com/support/index.aspx?id=401) is a list of a few reasons, from the lightscribe website.
Mar 03, 2011 | HP Hewlett Packard HP DVD557S 8x USB Slim...
When I try to burn a laber I get a message that the lightscribe drive is not recognized (520) the disc chbn@comcast.net
Try reading a disc from it. If that won't work, your drive is dead. Try upgrading your drivers, or upgrading the lightscribe software.
Dec 30, 2010 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP PAVILION a6000n with lightscribe supermulti drive / cd writer---windows vista :: does not recognize dvd disc when inserted
If it fails to recognize and CD or DVD that's inserted you will need to reinstall the driver for your LightScribe. The factory drivers for your system can be found here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=3548643
If it fails to recognize just one CD or DVD, chances are that the disc is defective.
Dec 02, 2009 | Cars & Trucks
Use lightscribe drive from laptop
I assume you want to use that drive so you can use it to label the CD/DVD you create. All you have to do, is create the disk on your laptop and then insert that very same disk upside down into the Lightscribe drive on the other computer and label it.
Nov 23, 2009 | HP Photosmart C8180 InkJet Printer
I've installed my lightscribe dvd/cd burner the only disc that came with it was nero 7 essentials i installed that but i cant get it to run the lightscribe when i put the disc in on the side to burn a cd...
You need to use a disk made for Lightscribe. Lightscribe technology was developed by HP.
Look at your local store that handles CD's, and DVD's, and look for the Lightscribe disks.
More information about Lightscribe,
http://en.wikipedia.org/wiki/Lightscribe
Oct 22, 2009 | QPS Que! Fire CD-RW Burner
I downloaded free light scribe software but it
I recommend you use Lightscribe system software
use this link I have provided to download and install Lightscribe softwares.
http://lightscribe.com/DownloadSection/mac/index.aspx
Good Luck.
May 14, 2009 | Computers & Internet
HP LightScribe 740i dvd burner/ wont read dvds
u try using 80 conducter cable,if u using 40 conducter cable ,
regards prasanna
Mar 03, 2008 | Computers & Internet
Nero 7 essentials - Lightscribe
you need nero 7 ultra edition
here is an illigal serial that will work
1C82-0000-19E5-MAAX-4006-2884-5247
Jan 01, 2008 | Computers & Internet
Open Questions:
AGPtek 8X LightScribe DVD RW Burner Drive For HP G60 G61 G70 G71 HP Pavilion dv3 dv5 dv7 DVDRW Burner Logo
Top AGPtek Computers & Internet Experts
David Payne
David Payne
Are you an AGPtek Computer and Internet Expert? Answer questions, earn points and help others
