Question about Frigidaire FRS26R4A Side by Side Refrigerator
Freezer and Refrigerator temperatures on control board say 32 degrees constantly, and also says adjusting temperature, and the refrigerator lights don't work, it cools fine, and freezer freezes fine and freezer lights work.
  • Frigidaire Master
  • 842 Answers
Check the bulbs first, if they look ok, replace the light which. Light bulbs are standard 40 watt found everywhere.
Good Luck
Posted on Nov 17, 2013
SOURCE: Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Posted on Jan 18, 2009
aborcass
  • 2651 Answers
SOURCE: Freezer Not Freezing
sounds like youll need to order and install one of these, its too cold in your garage to operate normally, this is a simple solution that should correct your issue
http://www.frigidaire.com/tip/US%202008%20Service%20Flashes%20and%20News/Refrigeration/2008/Service%20Flash%20RF083FRIG%20Garage%20Kit%20for%20Top%20Mounts.pdf
Posted on Jan 21, 2009
SOURCE: Freezer compartment temperature at 30-32 degrees F
HE'S correct i've seen many refrigerators with the same problem as yours.
Posted on Jan 05, 2010
Sea Breeze
  • 4655 Answers
SOURCE: freezer runs constantly. food freezes in bottom
I see this happen a lot on these models. The defrost control board is part of four operations. If you changed the Defrost control board then one of the two thermostats is not responding to changes in temperature settings. For freezer if turning the thermostat warmer should cause the compressor not to run as much and open the damper and regulate. If the only place the thermostat setting is placed to off and it responds only to off I would believe that thermostat is the reason. I believe you are on the right track to repair but if you have a look at the wiring diagram you see the connection and point I'm trying to make here. Let me place the diagram and send you a link shortly, Thanks, Sea Breeze
Posted on Feb 20, 2010
SOURCE: freezer won't freeze, but refrigerator section
one problem i had was the condensor fan had stopped working because it was clogged up with ice buildup, check and make sure the fan is not iced up, once a year i have to unclog ice from the condensor fan which located behing the white panel, which you unscrew and you can get a visual on this fan. my freezer would stop working but the fridge part was fine. something as small as that was causing this problem for me.
Posted on Apr 25, 2010
What is the mormal temperature swing of a Refrigerator?
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
Jun 11, 2014 | Kenmore Side by Side Refrigerator
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
How can I get into the cut-on settings of refrigerator
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this help in solving the problem....
May 12, 2011 | Refrigerators
How do I regulate temperature
I hope this will help in solving the problem.......
May 09, 2011 | Samsung RF265AA Bottom Freezer French Door...
How to set up the temp. please
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
The GE Profile PDS22sfsarss is now 4 1/2 years old. One year ago, the temperature panel stopped working and a repair person told me to just order that circuit -- which I did and replaced it myself....
Not certain this will help your situation, but here is what I did to mine.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which probably reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Jun 11, 2017 | GE Profile PDS20SFS Bottom Freezer...
I have a Samsung refrigerator/freezer How do I adjust the freezer temperature?
1Place the appliance thermometer in a glass of water.
2Set the glass of water with the thermometer in the refrigerator on the middle shelf.
3Check the temperature on the appliance thermometer after 24 hours.
4Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can’t easily see the control dial, check the owner’s manual for a diagram that shows the location
5Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
6Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
7Wait at least 24 hours, and then check the refrigerator temperature again.
8Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
90Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
10Repeat the steps as necessary until the temperature is within the safe range.
11Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this helpout...
Aug 09, 2010 | Samsung Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
