Question about Dell 2135cn All-In-One Laser Printer
What is initialize nvm on dell printer - Dell 2135cn All-In-One Laser Printer
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
Sep 06, 2015 | Xerox Office Equipment & Supplies
How to reset admin password for a xeror phaser 360 printer
Try this:
If you have set an admin password for CWIS (CenterWare Internet Services - your webGUI) then this procedure should reset that password.
  1. Press the Menu button on the control panel.
  2. Select Admin Menu
  3. Select Network Setup
  4. Select Reset Defaults
The other reset procedure is going to initialize all of the machine's NVM (Non Volatile Memory). Note: this procedure, and the one above, will not roll back the f/w on your machine.
  3. Select Maintenance Mode
  4. Select Initialize NVM
Taken from here
Sep 29, 2013 | Office Equipment & Supplies
Lost password dell 1320c
To fix this-
Restore to the factory settings:
1. Power OFF the printer and DISCONNECT any data cables.
2. Open the side cover.
3. While pressing the Continue and Cancel buttons at the same time, turn on the printer.
4. CONTINUE to PRESS and HOLD the Continue and Cancel buttons until ALL the indicators are turned
on, then release the two buttons.
5. After the Continue, Error, and Ready/Data indicators go out, close the side cover.
The printer will:
* Initialize the non-volatile memory (NVM).
* Restart
* Prints the Printer Settings and Device Settings pages.
CAUTION: DO NOT turn off the printer during this process or the printer will cease to function.
Aug 19, 2012 | Dell 1320c Laser Printer
How make reset factory dell 3110
For the 3100cn, once the web password has been set, you need to do a deep NVRAM reset to clear it.
Before doing anything, print a Printer Settings page so you know what your printer settings are, espcially page count. I might advise dating and saving this for possible future reference
Here's how to deep reset NVram for the 3000/3010/3100cn printers:
1. Pwr Off
2. Hold the Left + Right + Menu buttons while you Pwr-on (release them when display = DIAGNOSING...)
3. At the PASSWORD prompt, press UP, UP, [enter] (enter=center button)
4. Down button to INSTALLATION SET; [enter]
5. Down button to NVM Init; [enter]
6. OK?, [enter]
7. After completion message, Pwr off, wait 5 secs, then pwr on
After pwr on, the LCD displays "Init NVram" & "Initializing", then completes POST with "Diagnosing".
After printer completes POST, the toner level indicators on the LCD may show empty. The printer will need to be Pwr'd Off/On once again to correct display.
The procedure for the 3110cn is nearly identical. Let me know if you have problems figuring it out.
Jan 02, 2012 | Dell 3110cn Laser Printer
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
Dc 236 machine has a fault code 010-320. fuser is new, lvps is new and so the small board, i dont know the name of that board... but still 010-320 is there... trying to reset the value of nvm from 2 to 0,...
Well since you know how to enter diagnostics. Go to DC132 and select all copier nvm. Do an all copier nvm initialization, it will correct any default errors in the memory.
You will just have to then reset things like the power save timers and I would also go in and do a dc604 registration adjustment.
Apr 18, 2011 | Xerox DocuColor 3535 Copier
Pls help me: xerox workcentre 24 code: 116-372
Ugh.. That is a formatter software issue. Try these resets
arrwup.gif Log Initialization
This step will delete any print or copy job that is in process, and then perform a reboot.
To execute: simultaneously press and hold the 1, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif Spool Initialization
This step will delete all pending print or copy jobs in the job queue, and then perform a reboot.
To execute: simultaneously press and hold the 6, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif HDD Initialization
This step will delete all pending print or copy jobs in the IOT job queue (DC 3535: does not delete any job data stored in the Network Controller), initializes the IOT HDD (refer to ADJ 9.8 for details), and will and then perform a reboot. All customer data on the HDD will be deleted.
To execute: simultaneously press and hold the 4, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
arrwup.gif ESS NVM Initialization caution.gif CAUTION
This routine will set all IOT ESS NVM values to default. Do not attempt this procedure unless there is a known-good Machine Settings floppy, an accurate Configuration Report and/or other data that will enable you to reload the correct NVM values for this machine.
This step will initialize the IOT ESS NVM (SYS-System and SYS-User) and then perform a reboot.
To execute: simultaneously press and hold the 3, the Stop, and the Power Save buttons on the Control Panel while switching on the power. Hold the buttons down until the boot up screen (5 circles) appears and the second circle starts to blink.
If these do not work the system software needs reloaded or the ESS network board needs to be replaced.
Mar 12, 2011 | Xerox WorkCentre M-24 Color Copier
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Dec 24, 2008 | Xerox DocuColor 12 Printer
Dell 2135cn All-In-One Laser Printer Logo
111 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
