Question about Dell 924 All-in-One InkJet Printer
Dell 922 I got an error message 1200- carrier cartridge stall. The path is clear but I recently changed the cartridge. The print cartridges are under the units houdsing and inacessible. How do I get to them w/o breaking the printer?
  • Gary Z. Oct 07, 2007
    Actually, what it says is "PRINT CARRIER STALL"
  • Gary Z. Oct 27, 2007
    The print cartridges are clear now but I still get error 1200 - Carrier cartridge stall.  Now what?
TRY UNPLUGGING PRINTER FROM WALL AND PLUUGING IT BACK UP allow cartridges to unlock lubricate you carrige bar with 3in 1 oil while it is off the carrige bar is the silver bar the ink cartridge assembly travel along use only two or three drops of oil.
Posted on Jan 08, 2008
SOURCE:
THE UNIT SHOWS ERROR CODE 1200
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem: http://bit.ly/XypLZK
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
Printer Carrier Stall
You may have had a foriegn object fall inside the printer such as a pen or paper clip.You may also have a broken sensor which enables the carraige to move to the centre when the lid is open. You can try and carefully move the carraige over manually when the printer is turned off to see if there is something blocking its path. If the sensor is broken you can replace the cartridges by moving the carraige over when turned off.
May 28, 2010 | Dell 922 All-In-One InkJet Printer
Printer not printing display error 1200 only.
Hi
Ok you can try this.
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 17, 2010 | Dell 922 All-In-One InkJet Printer
I keep getting ERROR 1200 - Print Carrier Stall - there is nothing blocking the cartridges and I have even replaced them. I am using Dell cartridges. What else could be causing this problem? It stalls...
Hi
Error code: 1200
Hope you get it to go.
Feb 06, 2010 | Dell 922 All-In-One InkJet Printer
Dell 922 print carrier stall error message. Also, error 1200.
Hi
hope it will work
Error code: 1200
Nov 18, 2009 | Dell 922 All-In-One InkJet Printer
The printer has an error stating ERROR 1200
Jan 30, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
I get message carrier stall - error 1200
Try this 1.Disconnect power to printer 2. Force the cartridges to the left and then to the right 3. Clean at the transparent strip behind the cartrigde holder (Encoder strip) Be careful not to pull on the strip Hope this helps.....
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Ink cartridge
Not quite sure what you mean but if it is stuck under the housing then that would give the error. Could it be that the cartridge wasn't installed straight and this has caused it to become jammed?
Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall.  The carrier moves fine when I turn it on, in fact it slams to the right!  Will not print at all!
Mar 23, 2007 | Dell 922 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
119 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
