Question about LG 42" 5700 Series LED HDTV - 42LN5700
LG LED SmartTV is power on/off looping. Can I use the TV's PSB to power a cooling fan?
The only solution I have seen so far that has fixed the infinite power loop issue has been a firm whack the area just above the power input on the back of the TV where the PSB resides. This leads me to believe there is an electromechanical contact that is occasionally malfunctioning. I want to add a fan to the CPU and power supply, as well as an exhaust fan where the vent on the back panel is pre-cut (which makes you wonder why they didn't just put a fan there in the first place). I realize it is likely not advisable, but I was wondering if anybody has had success running a 12V pc cooling fan with a relay off the TV's PSB. Help me brainstorm!
  • Austin Andres
    Austin Andres Nov 16, 2013
    I suppose the smarter thing to do would be to run an externally, or USB-powered, fan and a smart, auto-switching surge protector.
  • Austin Andres
Coldcut
  • 1554 Answers
SOURCE: LG 42KK Power Supply Schematic Requested
you won't find any just ,
use a thermal probe or thermal gun as heat is likely the issue ,
if nothing else replace the main diode /rectifier and caps.
I find that if I replace the hottest items that usually the fix
if there is room for a small fan you will be doing them a great service and extend the life of the tv.
you may find some info on the power supply from one of these links they are generic enough
http://www.pacificdisplay.com/links.htm
Posted on Jun 10, 2008
  • 83 Answers
SOURCE: Power supply unit, TV cuts off after 20 seconds
i would recommend ebay, they usually have lots of parts for lcd tvs
Posted on Jan 25, 2009
  • 88 Answers
SOURCE: HELP OTHERS LG32LC7D FLAT PANEL TV
you case a little difficult. you not a technicion. hard to tell me about that connect the cooler fan to tv inside circuit . if you understand that transistor like # kia7812p1.that "s has 1 input . 1 output & 1 ground connection. if take a cooler fan " + "wire connect to that output of transistor & "-- " wire connect to tv dc ground. that " s be cooler fan working when tv on. hopefully could help you. christopher. but that connection i never did it before. good luck!
Posted on Apr 29, 2010
  • 222 Answers
SOURCE: Need a new power supply. Where?
Try E-bay
Posted on Jun 06, 2010
Testimonial: "THanks."
SOURCE: My TV a LG 52LG60 52 in. "Scarlet" HDTV LCD TV
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, So the power supply tries to do this, however when it does, the fault, is temporarily removed, (Usually because the faulty component cools down) and then, it restarts up again, senses the fault, and shuts down, and then... and so on...
We call this a "Hicupping Power supply" This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Please find below FYI a Training manuals, this is what I use to teach the technicians to troubleshoot and understand just how it all works and what to do,and how complex and difficult, these units are to service.
www.scribd.com/doc/.../Lg-Plasma-Tv-Full-Training-Manual
www.scribd.com/doc/.../LG-LCD-TV-42LP1D-Service-Manual
Posted on Aug 21, 2010
LG 55LV5500 turns on but no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 11, 2016 | LG 55LV5500 55 Class 1080P 120Hz LED TV...
My LG 42LN5400 LED TV turns off and on in an endless loop. There is some light on the screen when it comes on, but then goes black before turning off. What part needs to be replaced to fix this?
seems like the issue with the power circuit .. the LED must be fine that is why you see the back light when powering on ..
do not replace any parts manually, call in a technician, incorrect part can do more harm than good.
Jul 23, 2015 | LG 42" Ln5400 Series Led-Lcd Fu1080P...
No video no picture, caps look okay, what could be wrong or how to tshoot to determine which PCB is bad etc
Does the screen flash on briefly then go black when first switched on? See my posts in march for my answer to this fault.I traced the same fault on my own tv down to a faulty led in the backlight strip. Also my tv did the same thing,standby light flashed twice and then went out.Hope this helps
Feb 21, 2015 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
My lg tv has a green tint to the screen
Sounds like a bad T-Con board which is the board at the Top-Middle of the set. I have also seen the display bad causing that problem in Lg's. Have it looked at first.
Mar 06, 2013 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
Tv will intermittently not turn on. when i press the on/off switch i hear a click then i hear fans start up - the fans will die down to a steady speed. no raster. press on/off a few times then tv video...
Your Caps on the PSB- Power supply board are on their way out. Pretty soon it won't turn on at all. You will only get the Fault code blinking LED at startup. Recap the UF capacitors on the PSB. Works 90% of the time.
Jun 30, 2010 | LG MU-50PZ90C Television
Tv will not power on. Led light is meaningful.
Is very unlikely that the backlight inverter board is defective, even if it was the tv should power ON but will not illuminate the screen and no video.
Check this link to find the power supply.
Jul 25, 2009 | iLO 3200 32 in. LCD Television
LG 42" 5700 Series LED HDTV - 42LN5700 Logo
Computer Repairing
Computer Repairing
