Vizio vertical line
I have a couple of issues with my Vizio M550NV 1. There is a dark bar across the left 8" or so inches of the screen. I can move my cursor over it and still see my cursor. Toward the bottom of the bar the picture bleeds into the dark bar a bit. I've cleaned and re-seated the flat collectors from the board to the panel and saw no change. Any ideas? 2. After the TV's been on for a bit, the right side of my screen starts to show horizontal static lines and a 2" black bar appears down the center. If I play with the flat connector it goes away. 3. I have a few vertical lines (red, blue, black) going from the top to bottom of my screen. Any ideas?
    Top Expert:
  • Televison & ... Master
  • 74,844 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Apr 03, 2017
4 Suggested Answers
  • 225 Answers
SOURCE: Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Posted on Jan 08, 2009
sams_trix
  • 93 Answers
SOURCE: Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Posted on Aug 30, 2009
SOURCE: 46 inch Sony flat panel lcd has vertical red and
If the screen works for a short while and then completely fails once the TV warms up you have a problem with the main unit video board or the LCD control logic board. Most often if the picture cuts out but audio continues to work the logic board is over heating and should be replaced. However if the picture cuts out and audio shuts off as well then its your video input board.
Posted on Oct 16, 2010
Horizontal lines on led/tv with rolling vertically.
This sounds like a panel issue unfortunately, if its under warranty or you purchased an extended warranty great, if not your kind of SOL
Nov 26, 2017 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio display issues
Apr 03, 2017 | Televison & Video
Left half my my screen has different color bars running vertically down it
Your tv have problem with the T con board. T con board is one wich drives the pixels in the LCD panel. There is no repair possible with these boards. You have to replace the T con board. Normally you can find the t con board in the top centre or the bottom centre of the tv covered with metal cover or aluminium foil.
Here i have added the link for T con board you can fin the picture of the board in the link
Ajin
http://www.ebay.com/itm/Vizio-M550NV-T-Con-3655-0022-0147-4A-0170-2372-0024-/280719517500?pt=LH_DefaultDomain_0&hash=item415c2fe73c
Feb 09, 2012 | Vizio M550NV 55 in LCD HDTV
I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Oct 19, 2009 | Vizio Televison & Video
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
