Can a base dvd player DV-2301 play both NTSC and PAL. I am in Australia and the DVD is from US (says NTSC) I know most recent players can do both.
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: DVD Player NTSC / PAL inter-compatibility
Appreciate the direct "Ask Me".
Emerson brand is not readily available in my country and therefore we have limited exposure to their various products. Although from what I was made to understand, more often than not, Emerson units are specifically manufactured for the US market and therefore would have limited or no multi region capability. Sorry. Although normally, the NTSC/PAL feature (if ever available) would be clearly marked in the box or in the manual or as a sticker on the unit itself.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 10, 2008
  • 56 Answers
SOURCE: Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Posted on Jun 12, 2009
  • 133 Answers
SOURCE: I have a coby dvd player hooked up to my new Vizio
Press N/P button on remote, if that dont work, go into the Setup Menu and do a DEFAULT. If either of those dont work, check to make sure your video cable is in the correct location.
If your in U.S., should always be on NTSC
If outside of U.S., you would select PAL
Posted on Jun 04, 2010
bugoy31
  • 1238 Answers
SOURCE: I have a Dynex DVD Player. It plays NTSC DVD's
Good day!
I want to know what is you location/country?
you DVD don't have any problem its normal for all DVD players.You cannot play both PAL and NSTC in good picture because it depends on your country or location.
this are the country that plays in NSTC:
NTSC
Canada
Chile
Costa Rica
Cuba
Dominican Republic
Ecuador
Japan
Mexico
Nicaragua
Panama
Peru
Philippines
Puerto Rico
South Korea
Taiwan
U.S.A.
thank you.I hope this info will be helpful
Posted on Jun 01, 2011
I am trying to play dvds from England (Region 2) on this dvd player and bought it specifically because it is region free - plays NTSC and PAL, so thought it would be an obvious choice. I can get the dvd to...
Are you in the US? Your TV system is NTSC. The player possibly plays NTSC and PAL(European system) discs on PAL TVs only. Try to find out from the user manual of the DVD player if you can change the output signal to NTSC. Now it is PAL even though you are playing NTSC discs.
Oct 14, 2013 | Pioneer DV-3032KV 1080P Upscaling Region...
Region codes
dvd players are suitable for all regions but the pins may vary region to region
May 13, 2008 | Sharp DV-NC200
Hello bought DVD player that says: multiregion intolerancia Today I realized that multiformat IS NOT The same that multiregion. I need play Pal dvd's so Any one know where can buy one of this. Or in
Where do you live? Different vendors may offer different models.
J&R has the Pioneer DV-610AV-s, http://www.jr.com/pioneer/pe/PIO_DV610AVS/ , region-free DVD player that claims to output to any TV (PAL, NTSC or SECAM) if the unit is in Auto mode. To change the setting, turn off the unit (put it in Standby) and press the Fast Forward button on the front panel (not the remote). Then toggle through the options by pressing ON/Standby (NTSC, PAL and Auto are the options). This unit has a 90-day warranty with J&R. Documentation for the model is available here: http://www.pioneer.eu/eur/products/archive/DV-610AV-S/media.html . Expand the section marked Manuals. It will have a problem with some DVDs created on a computer (UDF) if they are not finalized.
The Panasonic DMR-ES18 PAL/NTSC Region Free DVD Recorder available here, http://www.world-import.com/Panasonic_DMR-ES18_Region_Free_DVD_Recorder.htm , will let you play a PAL format video on a NTSC TV if you add a converter. See http://www.world-import.com/samar.htm for a few ideas.
I hope this helps.
Oct 04, 2012 | Televison & Video
My onkyo dv-cp701 only plays dvds in black and white?
change the format of output from ntsc to pal or pal to ntsc
Apr 02, 2011 | Onkyo DV-CP701 Multi-disc DVD Player
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
Feb 27, 2011 | Televison & Video
What is the Toshiba RD-XS34 region-free code? I live in Australia, and would like to play a dvd I have brought from America..
DVD player region-free codes.The DVD player can play both NTSC,and PAL.Play all NTSC DVD this format is in US,Canada,Mexico.PAL DVD format is in Europes,Asia,and Middle East.
Mar 21, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
I bought pioneer muti system dvd
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Mar 04, 2010 | Samsung DVD-V90K Multisystem DVD/VCR
Feb 19, 2009 | Panasonic DMR-ES35VS
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
