Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Fex831 dryer timer doesn't advance...what will i need to fix this myself?
The dryer timer doesn't advance; when I put it on 40 minutes it stays on 40 minutes the whole time it is drying clothes; the heater in the dryer works so we are still able to dry clothes...but it does not auto shut off
  • 2 more comments
  • Patrick Brethen
    Patrick Brethen Nov 18, 2013
    I think my original comment is a bit hard to follow...i'm going to give it another go here.
  • Patrick Brethen
    my dryer works...the heat works, and clothes get dry; but i have to set a timer on the microwave to remind me to turn the dryer off because it won't stop by itself...it ran for 9 hours straight last weekend because I forgot it and fell asleep. I think it may be the timer...? ideas?
  • Patrick Brethen
    what would you try first? (this is one of those combo units with the front load dryer on top of a top load washer...all one unit)
  • Patrick Brethen
    oh yeah...it will be 6 years old in february
  • Official Brand Answer
  • 4,342 Answers
Good Morning Patrick, thank you for allowing me to assist you!
Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your appliance on. If resetting the power does not correct the issue, and based on the symptoms you are describing, you may have a communication error with the control board, the timer itself may not be operating correctly or a potential wiring failure. Because it could be a number of any one of several underlying causes, you may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Posted on Nov 20, 2013
SOURCE: dryer sometimes works other times doesn't
Check and make sure there is not lint build-up in the venting hose leading to outside. This will cause longer drying times and can be a fire hazard. Also, if you use the Aluminum venting hose instead of the white plastic it can cut up to 30 min. off your drying time. It is a lot safer then the white venting hose which can also be a fire hazard. Make sure all the lint is cleaned out from the inside of the dryer where the venting hose is connected. It could be a clog there. This sounds more like the problem since the clothes are actually drying but it could be a partially burnt out heating element. Good Luck.
Posted on Dec 26, 2007
ngfam1
  • 639 Answers
SOURCE: Drying slow
Hi, Marvin,
My name is Neil and i am happy to help you and give you good advice!
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Or if you like,
You could call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Posted on Aug 24, 2008
  • 38 Answers
SOURCE: Our dryer will not dry clothes well - we have to
If you have checked the vent lines and the lint filter something else you can check is the air tube that connects the lint filter with the blower (behind slanted panel above washer lid). There is also a tin cover you must remove under the painted cover. There are no clamps or fasteners to hold this tube in place and a careless service man or a bad move could cause it to become misaligned. If the tube isn't tight against the blower it will **** cold air from the bottom of the machine, cutting down on the amount of hot air it pulls from the top (heater area).
I put three small kinks in the tin panel forming a triangle to make it hold pressure on the tube to keep it tight against the blower.
Good Luck
Quentin
Posted on Oct 04, 2009
  • 7 Answers
SOURCE: dryer will not heat-up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Posted on Nov 13, 2009
  • 53 Answers
SOURCE: My Frigidaire - Gallery Series - stackable
ABSOLUTELY! There is a plastic piece in the back that the center ball piece on the back of the drum spins in. Thats your bearing, replace it.
Posted on May 21, 2010
Dryer does not stay running
Replace the timer...
Mar 08, 2014 | Dryers
My Kenmore HE4 electric dryer runs for 2 minutes and stops
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replac it. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
Dryer wont stop buzzing
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
I have a Avanti dryer and after its on a few minutes it also cuts off. Can you tell me why or what to do to fix this problem?
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub.Replace the Heating Elements
Oct 17, 2012 | Avanti D110 Electric Portable Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
Timer
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
My dryer recently started staying on indefinitely or until I physically open the door. Is there something I can do to fix it? Is it a timer issue?
Have you tries running the dryer on all the cycles? If you have and it acts the same on all the cycles then it is a bad timer.Best thing to do is set the timer on the timed cycle for about ten minutes and if it doesn't advance then you know the timer needs repalced.
Mar 05, 2011 | Maytag Dryers
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
