Carrier 58dhc I get a relay that clicks and nothing else. Circuit board has two pins for self-test but no info on how to initiate
  • 69 Answers
Some self test s are initiated by momentarily jumping two test pins or some need to jumped while goes thru test mode then when test mode done just remove jumpers.
Posted on Nov 19, 2013
MY 1995 PONTIAC FIREBIRD HAS NO RESPONSE WHEN I TRY TO START IT,WHATS GOING ON,CAN YOU HELP ME
Do you know how to do automotive electrical circuit testing ? How to use a DVOM- digital volt ohm meter ? How to read an use a wiring diagram to pin point testing areas in a electricl circuit . Free wiring diagrams here - http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size. Under system click on engine ,then under subsystem click on starting . (That is if nothing happens when you turn the key to the start position. No click no nothing ?) Click the search button then the blue link. Is the theft system light lit ?
How to voltage drop test starter motor circuit
Jul 18, 2017 | Pontiac Cars & Trucks
1998 Sable will start and drive then after shutting it of won't start not even try to turn over for hours maybe a day then will start right up
When it won't start testing the electrical systems is the proper way to find a fix . Using a DVOM - digital volt ohm meter and power flow diagrams . Using voltage drop testing !
How to test starter engine doesn crank GM 3800 engine
Electric Testing Techniques You Need to Know
Do you know what a wiring diagram is ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Click on engine under system then under subsystem click on starting .Then click on the search button , then on the blue link . This is a wiring diagram of the starter electrical circuit. Do you know what ignition switch is ? the electrical part. , how about the starter relay , transmission range sensor ! There is one thing you can try , move gear selector to neutral an see if it starts then . If that does nothing ,check for B+ voltage going at the starter relay . Jumping pins 30 & 87 at the relay socket , where the relay plugs into . will cause the starter to engage an spin the engine . If you look on the bottom of the relay you will see four sets of numbers 30 & 87 - 30 should have B+ voltage , 87 goes to the S terminal on the starter solenoid . An 85 & 86 are the control side .86 at the relay socket comes from ignition switch through the trans range sensor to the starter relay coil ( electro magnet ) . Watch these videos too .
VEHICLE RELAYS Testing from the relay base
VEHICLE RELAYS Operation Diagnosis
Apr 29, 2017 | 1998 Mercury Sable
I have a 2011 for fusion sel.I would turn the heat on and nothing let it on and it would come on by it self or if I hit a bumb. But now I turn the heat on and nothing
https://s16.postimg.org/45t9z2551/auto_hvac.jpg
Click on the link.
Your saying the blower motor won't work? I can help with testing, but, you have to do the testing.
I looked at info for automatic hvac, see those two fuses, not only check the fuse, use a test light and check fuse circuit for voltage. As you can see, one fuse is hot all the time, the other fuse goes hot with the key on. See the relay, if you use a jumper wire on load side of relay, terminal 30 and 87, you can bypass the control side of relay.
Any hvac trouble codes? Could be loose wire, loose wiring connector or faulty blower motor brushes. There is a speed control module, also.
Apr 12, 2017 | 2011 Ford Fusion SEL
Rear suspension will deflate but why won't it inflate?
That could work , You mite be able to test the sensor in question with ohm meter . Test the front one an see what the resistance is ,then check the back one. I don't know what it should be with out looking it up in the service info . You could also check to see if the sensor is getting power from the control module , an see if there is a return input to the module .
There are a few DTC'S this able to set !
Air Suspension Control Module Diagnostic Trouble Code (DTC) Index
Air Suspension Control Module Diagnostic Trouble Code (DTC) Index DTCs Description Source Action B1318 Battery Voltage Low Air Suspension Control Module Go To Pinpoint Test C . B1342 Air Suspension Control Module Air Suspension Control Module INSTALL a new air suspension control module. REFER to Module-Air Suspension Control . SET the front ride height. REFER to Air Suspension Initialization (Clear DTC B2140). CLEAR the DTCs. REPEAT the self-test. B1485 Brake Pedal Input Circuit Battery Short Air Suspension Control Module RERUN On-Demand Self-Test. MAKE SURE that the brake pedal is not pressed. If DTC is returned again, REPAIR brake pedal position (BPP) circuitry. B1566 Door Ajar Circuit Short to Ground Air Suspension Control Module Go To Pinpoint Test D . B2140 Initialization Failure (Vehicle Ride Height Not Programmed) Air Suspension Control Module REFER to Air Suspension Initialization (Clear DTC B2140). C1439 Vehicle Acceleration EEC-V Circuit Failure Air Suspension Control Module Go To Pinpoint Test E . C1724 Air Suspension Height Sensor Power Circuit Failure Air Suspension Control Module Go To Pinpoint Test F . C1726 Air Suspension Pneumatic Failure Air Suspension Control Module Go To Pinpoint Test G . C1760 Air Suspension Height Sensor High Signal Circuit Failure Air Suspension Control Module Go To Pinpoint Test H . C1770 Air Suspension Vent Solenoid Output Circuit Failure Air Suspension Control Module Go To Pinpoint Test I . C1790 Air Suspension LR Air Spring Solenoid Output Circuit Failure Air Suspension Control Module Go To Pinpoint Test J . C1795 Air Suspension RR Air Spring Solenoid Output Circuit Failure Air Suspension Control Module Go To Pinpoint Test K . C1830 Air Suspension Compressor Relay Circuit Failure Air Suspension Control Module Go To Pinpoint Test L . C1917 Steering Electronic Variable Orifice (EEVO) Out-of-Range Fault Air Suspension Control Module Go To Pinpoint Test Q .
  • Uneven vehicle height
  • Circuitry.
  • Rear pneumatic fault.
  • Air compressor assembly.
  • Air suspension control module.
  • Go To Pinpoint Test I .
Nov 06, 2015 | 2002 Lincoln Navigator
High beams wont come on !!
What relay's an fuse's ? open and close circuit test to the bulb connectors ??????? Voltage testing with a DVOM - digital volt ohm meter !
B+voltage going into the multifunction switch ? Fuse F2.59 7.5 amp located in the central junction box . Green with red trace goes to mulitifunction switch (high beam ) pin #6 , Pin#7 multifunction switch green with yellow trace goes to control (energize ) High beam relay . Control side high beam relay grounds at G103 ! High beam relay located in the battery junction box . Do you know how to test for B+ voltage ? Forget this open and close circuit test . Voltage drop testing is the correct way to test a electrical circuit , the circuit has to be energized .
Do you know what a wiring diagram is ? Did you view a wiring to know what you were testing ? If know ,you can't say you have a compleat circuit. Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info ,under system click on lighting ,then under subsystem click on Head lamps . Click the search button then the blue link . Using a volt meter test .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
The high beam relay is c1050 ,thats the only one you need ! Do you know about relays ?
Jul 05, 2017 | 2005 Ford Focus
Location for ac relay on 97 ford taurus
Are you talking the ccrm? Those relays are soldered into the circuit board. Some of my ford info, says if the relays in the diagram have no terminal pin numbers, the relays are soldered into the circuit board, you can't pull it out. Sometimes It may be possible to use an external relay, wire it up properly and it should work.
If your talking about the ccrm/ constant control relay module, I'd probably just replace it, if that is the problem.
If your talking about a different relay then, I need more info?
May 30, 2012 | Ford Taurus Cars & Trucks
MY carrier model #58DHC with hot surface ignitor has quit working. Blower works, but no heat. If you turn the thermostat to on fan will run but no heat. Did preliminary testings with self test on printed...
If you suspect its the ignitor? The hot surface ignitor is powered by 120v. Inspect ignitors' hot surface for cracks or burnt spots. Uplug ignitor from board. Cycle heat on and verify 120v to the ignitor at the cannon plug on the board where the ignitor plugs in. If you have the voltage then replace the ignitor. If not, you'll need to verify all other circuits are working before condemning the board. Work safe and at your own risk! Hope this helps!
Mar 25, 2017 | Heating & Cooling
2002 Pontiac Grand Prix GT wont start. Has new battery. Starter was taken off car and works. Relays and fuses are fine. Power cables cleaned. Driver information center dim. Headlights are on when key...
PNP park neutral safety switch . Try moving gear selector to neutral . If it starts the switch is bad .
Voltage drop test starter circuit .
fusible relay ??? Now thats funny ! It's just a relay , not fusible relay ! A fusible link is a kind of fuse ,will melt with a short circuit. TEST ,TEST DON'T GUESS and if you can't test ,take it to a qualified repair shop. How to voltage drop test starter motor circuit
Starter Voltage Drop
The computer has nothing to do with it .
http://www.bbbind.com/free_tsb.html Free wiring diagrams ! Suggest you view a wiring diagram to see what all is involved in the starter circuit . NO starter relay ! Enter vehicle info. under system click engine, then under subsystem click starting . You will when you turn the key to start it send's B+ voltage to the PNP switch ,from there it goes to the S terminal on the starter solenoid . Very simple . Get a volt meter an test B+ voltage .
Jul 28, 2017 | 2002 Pontiac Grand Prix
At the test point on the circuit board there is no voltage on the other side of the gas valve relay. So the valve won't open. The switches all seem ok until it enters the microprocessor and then goes into...
If you positively have gas valve relay identified and it has power going in when thermostat is calling for heat but nothing coming out I would change the control board. Hope this helps. Thanks
Nov 18, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Lcd montior failure
standby light comes on then cuts out. i removed the board that connects power and noticed charring underneath a heat sink with a 5 pin connector to the board. have tested with a circuit tester and get nothing from the pins. can i get a replacement or would you advise a new board
Feb 17, 2008 | Computers & Internet
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
