Question about Agri-Fab Garden
Need agitator for rugid spreader - Agri-Fab Garden
Cyclone spreader parts
Cyclone spreader parts can be purchased from amazon, take a look here: Amazon com Cyclone spreader parts. Wish you best of luck
May 16, 2012 | Garden
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I have a Scotts Accugreen 3000 spreader. The orange plastic teeth on the rotating bar located at the bottom of the hopper are shorter due ot wear. What is the bar name, replacement part number, cost and...
I am sorry to hear about the problem with your spreader. It sounds that you have a broken agitator. We do have replacement parts available. Please call Scotts at 1-800-543-8873 at your earliest convenience. Hilary @ Scotts.
Jun 17, 2011 | Scotts Company Garden
Need the setting for a Scotts Pro edgeguard broadcast spreader for pre-emergent
Hi, W/D here.
The spreader setting instructions will be found on the back of the bag, and you will set your spreader gate opening accordingly.
Best regards, --W/D--
Feb 18, 2011 | Scotts Company Scotts Pro Edgeguard...
I need spreader setting to do 2.3 pounds per 1000 sq ft
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Feb 17, 2011 | Scotts Company Scotts Lawns Edgeguard...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
Lost agitater for my Scotts Spreader
I replaced mine with a clip-in cotter key, the kind they use for farm implements to keep a pin in place. I bought a stainless steel one at Lowe's for ~$1. Works at least as good as what I had.
Aug 08, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
Aug 27, 2008 | Agri-Fab Agri Fab Spreader
Garden Logo
29 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
