My car run fine yesterday, but today would not start. It would turn over, but would not run or start the engin
SOURCE: car won't start. turns over but stalls.
sounds like a fault in the theft deterrent
is the theft light on or flashing
you will need to have the scanned for codes
SOURCE: My battery keeps dying but my alternator is fine
First, DON"T check your alternator that way anymore. It's not good to do on newer systems! The best, quickest check I can tell you is to put a volt meter across the battery. Running with accessories off you should see voltage of about 13.5 to 14.5.
With all accessories and headlamps on high turned on, it should not drop below 12.5. (and that is the absolute low end!).
It sounds like something in the car is staying on. check the glovebox light and interior light delay and make sure they are OK. Otherwise, you will have to start checking entire system for a draw that's taking out the battery overnight. To check, you can pull one fuse at a time and see if draw goes away, then check system that fuse serves.
The battery will crake over and charge, but my can will not run
