How to enter self test on carrier crusader furnace
My carrier crusader wont do any thing. there is a self test pins on circuit board but i cant find info how to use it. do i short them or moniter them for voltage or resistance?
Therinnaiguy
  • 1420 Answers
SOURCE: Blower on Carrier Crusader Gas Forced Air Furnace problem
You have a system that is 20 years old. The cost of the repair may be 1/2 of a new unit. This unit will continue to fail and only cost you more that you can expect to get out of it.
Posted on Nov 28, 2008
farfield
  • 462 Answers
SOURCE: Carrier Furnace 58gs075-1 Circuit board issues...
I cant see your wire diagram but trace the circut your talking about. I believe it usually goes through a series of safety switches. Put your VOM across each individual switch. If you get 24 out from the board the first 1 you check and get 24v is open and not feeding back to the board is out. FIND out why. the switch could be bad but it may be indicating a more involved problem, just look aroeund for chared wires or tell tell signes of flame roll out or if its an open (fuse link) suspect what can cause an over heat condition anythign from a bad board or too long an off cycle before the indoor fan comes on ect. PONIT IS Once you come across the cause may not be the reason.
Please grade me accordingly and if you need more I need more info from you.
Posted on Mar 02, 2009
gear001
  • 59 Answers
SOURCE: Hello all, I have a Goodman GMPN 120-5 gas
Did you check the 24 Volt at common on the board. You might of short out the 23 V. Transformer. You need to check that out first. www.fastacservice.com
Posted on Oct 12, 2009
  • 767 Answers
SOURCE: carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Posted on Jan 03, 2010
SOURCE: fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Posted on Jul 16, 2010
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
On a Bryant furnace 373lav what is error code 41 furnace tries to light imonitor lights up but the won't light
Code 41= blower out of valid speed range. you will more than likely need a new motor module. they are not cheap 300$ to 400$. If you call a carrier or bryant tech out they should have a test module they carry on their truck that lets you know if its the furnace circuit board or motor module.
Jan 02, 2015 | Heating & Cooling
A carrier furnace model 58dla110---10122 won't start
Make sure the kill switch on the blower door is closed, or furnace won't do anything. Then remove power from furnace for a few seconds, then try again. Still no go? Take a jumper wire and jump the "r" terminal to the "w" terminal on the furnace's board. This bypasses the thermostat. This is only for testing. If it still wont run, call service guy. Gas furnaces are not good things to tinker with.
Nov 25, 2013 | Heating & Cooling
Carrier 58dhc
some self test s are initiated by momentarily jumping two test pins or some need to jumped while goes thru test mode then when test mode done just remove jumpers.
Nov 16, 2013 | Heating & Cooling
FURNACE LITES UP RUNS FOR 2 MIN. SHUTS OFF GAS.PAYNE
Carrier had a recall years ago on the HK42fz004 & I believe the 008 models because of intermittent problems like yours. Sounds like you need a new board
Jan 02, 2013 | Carrier Furnace Control Circuit Board...
Wiring diagram for carrier HK42FZ011 circuit board
Wire for wire if you are a novice. The schematic should be on the blower door just in case you get lost. I myself have changed hundreds of them and just undo the wires since I know where they go.
Jul 17, 2012 | Carrier Furnace Control Circuit Board...
Carrier Crusader Furnace Won't Light No Gas flow Gas is available Inducer fan starts when heat is demanded Igniter DOES NOT glow Igniter DOES glow during self test All other self test functions work...
Check all of the plastic tubing that connects to the pressure switches for any moisture build-up, crimps, or cracks and correct as necessary. :-)
Apr 26, 2010 | Heating & Cooling
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Nov 28, 2008 | Honeywell Programmable Thermostat Heater
Furnace Went Out! HELP PLEASE!!!!
The door closed or open should have no effect. The draft motor runs, no power to the glow plug or it is open,
The first place to look is at the furnace brain, a box located somewhere in the unit connecting to the gas valve, look at this brain [controller] and there should be a light of series of lights.
On the box itself there should be a matrix of codes such as: green light flashing= bad glow plug, or red, bad controller box, do you have anything like this?
Most have some sort of led light that narrows down the problem.
If not at least do these things:
make sure the power is off, and that the blower motor spins by hand freely.
next if you have a volt ohm meter, you can test the plug to see if there is a circuit, if the glow plug is open, that is one problem,
If you have a volt meter you can measure the leads at the plug to see if voltage is there or not.
There are so many checks and switches that will operate dependent on the operation of something else.
Unplug the furnace and keep the power off the brain, if so equipped for several minutes, see if it resets.
If it does great, if not tell me if there is a brain box and what the lights are, and what the matrix of light codes say, and we can go from there.
You can also measure for voltage from the thermostat to the furnace and make sure it is getting a signal on all wires, a thermostat wire could have come loose.
very difficult to troubleshoot a furnace when one is in front of it, let along without seeing it.
If you find no box, let me know, and let me know from these checks above if anything changes, or gives you more info to pass on to me.
Step at a time we can find this, a volt ohm meter will be really helpful.
Will
Nov 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
