Question about Napoleon Fireplaces Napoleon HD81 High Definition See Thru Direct Vent Gas Fireplace
Can't turn on the fireplace. the flame is too small
When I turn on the fireplace it has a small flame but stays like that. it won't adjust to a biggler flame, cant make any changes with the control or with the switch. what
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Can anyone tell me why my direct vent fireplace flame looks like its in a wind storm. The pilot blows out as a rexult
Looks like too much yellow in the flame. That is normally caused by the mixing control on the gas feed tube being too closed. Trace the tube from the burner .....back toward the gas feed line....until you find the slip ring that controls the amount of oxygen that is mixed with the gas. Open is a small amount and light it. You should see a bit more blue color. If that does not work, continue to vary the adjustment until the flame burns correctly. The pilot should never blow out unless the outside air feed is too large. You can try blocking it a small amount to see if the smaller amount of outside air corrects the problem.
May 16, 2014 | Home
My Valor fireplace won't turn off with the remote
Easy turn the gas cylinder close then its off,Or you could have a faulty control valve or thermo couple .Thermo couple is the small device looks like a probe to detect heat this is normally directly in the small pilot flame.The pilot flame if not burning will not open the control valve for the other burners to come on.If the other burners come on but do not go of when turned off. then need to check control valve.
Jan 06, 2014 | Televison & Video
Gas fireplace manuals
There are two things that control flame height gas volume and air volume. Some fireplaces have a flame control knob on the gas valvd to adjust flame height. Air volume is controlled by an air shutter usually located where the main gas orifice enters the burner. There is usually a small cover that will need to be removed to access the shutter. Closing the shutter will cause the flames to become taller and more yellow colored. Closing the shutter too far will cause sooting problems so great care should be taken in adjusting this shutter.As a rule, L.P. gas fireplaces do not have as high of a flame as natural gas unit do.
Hope this helps
Dec 14, 2013 | Heating & Cooling
Remote won't work unless next to fireplace.
There are some adjustments that can be made to improve the reception of the Skytech 3301 Fireplace Remote.
Sometimes the RF reception can be diminished if the receiver is in an enclosed metal surround such as a heat shield.
The link above will bring you to the product page where you can scroll down and download the full owner's manual. An excerpt from the manual in regards to adjusting the reception is below:
"RECEIVER ADJUSTMENT - RECOMMENDED ADJUSTMENT
NOTE: The slide button, Gray or Black, covers the ADJ access hole when installed.
A. To adjust at the receiver, use a small slotted screwdriver. Turn the adjustment screw counter-clockwise
about 5 degrees or a maximum of 1/8 turn. This should correct the distance problem.
B. If that does not correct the problem, return adjustment screw to original position and then turn adjustment
screw clockwise.
This adjustment is like tuning your radio. If you keep turning the adjustment screw, in either direction, you will go past the proper setting (tuning)."
Dec 25, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The pilot is off and I don't have the manual. How do I start the pilot to turn on the logs
You will need to find the gas valve. Open up the lower section of the fireplace and look foe a small cube of aluminum with a knob on it that says On-Off-Pilot. Turn the knob to the Off position by lining up the word with a small dot or line indicator on the body of the gas valve. Then turn the knob to the Pilot setting. You will know when you are in the correct setting because you will be able to depress the knob into the gas valve body. Hold the knob depressed and click the larger red button. It will snap so don't be startled. Continue to hold the knob in while looking between the logs for a blue flame. If you don't see one, keep snapping the red button. Once you see the flame, continue to hold the knob depressed for 30 seconds or so. Release the knob and make sure the flame stays on. If it does not, repeat nthis procedure and hold down the knob for 45 seconds. If the flame continues to go out, you need a new thermocouple. Once the flame stays lit, rotate the knob to the On setting. The main burner should start within 15 seconds.
Nov 26, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heatilator Pilot Issue
Any pilot adjustment would be under a large screw with a flat blade slot in it. There would be a smalled flat blade screw under it. Warning: Too small of a flame and your safety device won't work.
READ MORE
Jan 04, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Replace light bulb in a Charmglow electric fireplace
you have to remove the doors and then the lower ember cover, he lighs are underneath.... i am looking on how o make he flame move, it froze and won look like real fire anymore
Oct 21, 2008 | Kitchen Appliances - Others
Napoleon Fireplaces Napoleon HD81 High Definition See Thru Direct Vent Gas Fireplace Logo
22 people viewed this question
Top Napoleon Fireplaces Home Experts
Donni Steen
Tom Chichester
Are you a Napoleon Fireplaces Home Expert? Answer questions, earn points and help others
