Question about Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224
Schumaker battetry charger wiring diagram - Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224
Battery not charging
it may be the charger. if it is you can check it. first shutdown your laptop and then take out the battetry, plug in the charger cord, then turn on the laptop. if it turns on it is not the cord, it is the battery that needs replacement. if it doesnt turn on you just have to go to staples and get a new cord
Jun 25, 2013 | Lenovo ThinkPad T61 Notebook
Batter y charger goes to 10 amps then after2to4 minutes charger kicks off coming back on 1to 2 minutes but very little spark in battetry
Sounds like this battery may have a dead short in it. When the plates inside get thin, one can break and if it touches another plate can short the battery out, causing it to discharge. try the charger on another battery and see if it works. This will tell you whether the charger is bad or the battery is bad.
Mar 07, 2011 | Chevrolet Caprice Cars & Trucks
Need a wiring diagram for a clarion drx 5275 car am/fm cd player
COLOR FUNCTION
You may not have all the wires on the stereo but this list will help. Good luck and please rate.
RED ACCESSORY
YELLOW BATTETRY
BLACK GROUND
BLUE POWER ANTENNA
BLUE/WHITE AMPLIFIER TURN ON
ORANGE ILLUMINATION
ORANGE/WHITE DIMMER
GRAY RIGHT FRONT +
GRAY/BLACK RIGHT FRONT -
WHITE LEFT FRONT +
WHITE/BLACK LEFT FRONT -
VIOLET RIGHT REAR +
VIOLET/BLACK RIGHT REAR -
GREEN LEFT REAR +
GREEN/BLACK LEFT REAR -
Dec 02, 2009 | Clarion DRX5275
I want a wiring cirtcuit
The following should help you. You may not have all the wires listed, but use the ones that are. These are usually common aftermarket wiring.
COLOR FUNCTION
RED ACCESSORY
YELLOW BATTETRY
BLACK GROUND
BLUE POWER ANTENNA
ORANGE ILLUMINATION
ORANGE/WHITE DIMMER
GRAY RIGHT FRONT +
WHITE LEFT FRONT +
VIOLET RIGHT REAR +
GREEN LEFT REAR +
Dec 01, 2009 | Car Audio & Video
Looking for diagram on how to replace fan belt(alternator), on 1997 Prado RV-6
its got 2 belts drop lower shield drop condensr pulley then take out battery 8 bolts that hold in battetry box then 14mm adj bolt to alt then change belts tighten relace all.about an hour if not on driveway.battery box needs to be out to get room for alt
Nov 23, 2009 | 1997 Toyota Land Cruiser
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
12v battery powered barbie jeep
If you are comfortable with wires then go to walmart and get a schumaker battery charger from the automotive department. either the Maintainer or the next one up I think ist is model 600 They are much better than the stock chargers because when the battery is full they automatically switch over to float mode so the battery doesn't get cooked. www.modifiedpowerwheels.com has lots of info on exactly what you would need to do. The chargers are 20 and 30 I believe and they can be used for other things like lawnmowers and car batteries if needed.
Aug 11, 2008 | Jeep Yellow Sports Outdoor Power Wheels...
1968 dodge charger wiring diagram
resistor gets hot with ignition on
Aug 08, 2008 | 2006 Dodge Charger
Schumacher DSR ProSeries Battery Charger - 250/65/35/5 Amp, Model# PSW-61224 Logo
138 people viewed this question
Top Schumacher Hardware & Accessories Experts
jdthefixer
Are you a Schumacher Hardware and Accessory Expert? Answer questions, earn points and help others
