Question about Cooktops
Can't get netflex on my system - Cooktops
    New Friend:
My app for netflex
Posted on Dec 11, 2013
Wiring diagram
A wiring diagram is a simple visual representation of the physical connections and physical layout of an electrical system or circuit. It shows how the electrical wires are interconnected and can also show where fixtures and components may be connected to the system. Use wiring diagrams to assist in building or manufacturing the circuit or electronic device. They are also useful for making repairs. DIY enthusiasts use wiring diagrams but they are also common in home building and auto repair. For example, a home builder will want to confirm the physical location of electrical outlets and light fixtures using a wiring diagram to avoid costly mistakes and building code violations.
http://resumeplus.us
Sep 01, 2016 | Cooktops
Ladylibra2951
HI LINDA,
TRY DELETING THE APP AND REINSTALLING IT FROM THE APP STORE. IF THERE IS A PROBLEM WITH THE LOG IN THEN YOU NEED TO GO TO WWW.NETFILX.COM AND RESET YOUR PASSWORD, THEN TRY AGAIN.
Dec 27, 2013 | Cooktops
Spark module wont shut off once it has ignited. Do I need a new one
I would clean the electrodes on the burners really good, sometimes they seem not to sense heat from the burner and will not turn off the ignition system. Other times I fond bad grounds to the cooktop or outlet that can cause the same issue. The electrodes since heat from the burners to shut down the inanition system, also with out a good ground this system is impossible to work correctly.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 21, 2011 | GE Profile JGP636 Gas Cooktop
One burner is not working
The heat and pressure sensor is worn out! Be ready to perform the below type of work to fix the old one. Generally what occurs is the units soldered connections on the main power board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Jan 21, 2011 | Kenmore Cooktops
My GE Profile JPG636 cooktop has an ignitor problem. It clicks constantly, and all the ignitors on all 5 burners are 'going off'. It happens every 8 or 10 seconds whether we're cooking or not. If anyone...
The most common cause for this issue is from liquid getting into the ignition system for the range. If someone has spilled water or other liquids into the burner knobs or the ignition system it will cause an electrical short in the system causing the igniters to come on constantly when the knobs are off. The fix to this is to unplug the range and wait 24 hours for the liquids to dry up. You can speed up this process with a hair dryer pointed at the burner stems(knobs removed). Once the liquids have dried up the problem should stop. I would not leave it plugged in until then because the ignition system could be damaged from the constant sparking.
Feb 23, 2010 | GE Profile JGP636 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
Whirlpool gas range whistles when burners are turned on. What is the problem?
Your gas inlet valves are turned up to high or there is air in your system. Most of the time the burners are set either to high or to low. Meaning that not enough or to much gas pressure is being forced through the system.
Jan 01, 2010 | Maytag MGC6430 Gas Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Pilot Flame is too high.
You will only need to purge air from the supply if this is newly installed or if you have recently disconnected / reconnected the main gas supply for some reason. Otherwise, you can just skip that step.
If you do need to purge the system do the following:
MAKE SURE THE ROOM IS WELL VENTED TO OUTSIDE
REMOVE ALL SOURCES OF POSSIBLE IGNITION
Fully open the largest burner and allow to run until gas is smelt.
There is no way to say exactly how long it needs to be open as this very much depends on the length of pipework feeding the appliance, but in a typical domestic installation, this shouldn't be more than about 5-10 seconds.
Hope this helps,
Matt
Mar 03, 2008 | Maytag MGC5430 Gas Cooktop
Cooktops Logo
56 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
