Question about Car Audio & Video
Ouku LITB100-7 how do you enable the Bluetooth function and where do you insert the sd card?
  • 903 Answers
SOURCE: Rom Update
As far as I know there is a big difference between Japanese and European images and you can not compare them at all. If the Japanese image has a bug or if there is some problem that can be corrected with a new update that doesn’t mean that European units needs an update too. Many of your questions are not completely understandable and I can just give you an advice to use a new BT driver (question 5). I have also 1 GB SD card and I use it with my e800 without any problems. At the beginning I thought that it will be read slowly but I am very satisfied with reading/writing speed.
Posted on Sep 08, 2005
  • 16 Answers
SOURCE: Internal memory to sd card
I don't know your camera; but... Before we assume anything about your camera we should check that SD card in another SD device that we know is working. your camera should default to the SD Card like most devices, which are able to use both simultaneously. It seems likely that something might have happened to the SD card if that is the only one you have tried in your camera. food for thought
Posted on Aug 28, 2007
  • 14 Answers
SOURCE: Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Posted on Apr 10, 2008
  • 51 Answers
SOURCE: Can SD Memory cards be used with my Go 720??
the "no SD required" is just letting you know that all of the important stuff to make the unit run is all on the hard drive of the unit itself. Yes you can use a SD card to hold maps, photos, or music. For instance if you were going to Europe, you will be able to get a European Map and download it onto the SD card. Another instance would be if you wanted to download some mp3 files.
Posted on Sep 29, 2009
prashant2012
  • 1127 Answers
SOURCE: my mother sends me a
Hi
Just restart your phone, and try again, when your insert your SD card your mobile is not detected. so its necessary to restart the phone
Posted on Jun 05, 2011
When we bought the ouku 7 inch in dash navigation bluetooth stereo for our aunts birthday, when we received the product the sd card with the maps for navigation was missing. Can't get ahold of seller, so...
You can buy an sdcard from anywhere as long as it's the proper size then you should be able to download the maps from the manufacture and copy them to the sdcard and presto all done.
Jun 14, 2014 | GPS
Ouku GPS/DVD Can't find navigation software
Make sure your SD Card is inserted in the GPS SD card slot properly. it is located behind the head of the unit( where you insert your DVDs) usually has red or orange tape over it. just remove it and reinstall it. Hope this helps.
Jan 23, 2014 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
GPS says no application
Go into settings then guide settings. Tap the sd slot card so the radio can read it should work now
Jul 04, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
I WANT UNLOAD ALL THE PICTURES FROM MY SAMSUNG GALAXY S TO MY COMPUTOR
Hello there,
You have 3 ways to transfer your pictures from the phone to the PC. Via Bluetooth, USB cable and via the memory card. The bluetooth is a feature of your phone and you just have to enable it. Make sure that the computer has bluetooth functionality. The usb cable on the other hand can be directly connected to your laptop or desktop PC. You can transfer pictures from there by using the Mass Storage functionality on your phone. Third is via the memory card. You can use a memory card adapter and then install it on a computer with an SD / MMC adapter.
Apr 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
Palm Tungsten E2 doesn't recognize SD Card Card Info states that no card is inserted Card inserted with device on Card inserted with device off No recognition Kingston 4 GB
The problem is simply that the Tungsten E2 cannot read SD cards larger than 1 GB. However, there is a solution that will enable it to read larger cards. A driver called PowerSDHC is available from PalmPowerups.com that will enable the E2 to read cards of any size. I'm now running an 8 GB SDHC card on my E2!
Feb 17, 2009 | Palm Tungsten E2 (Multilingual) Handheld
I need down load photos off of my lg f1420 mobile phone
If it isn't Bluetooth enabled, best way is to use an SD card, save photos to it and download to PC using a card reader. If Bluetooth enabled, you need a Bluetooth dongle.
Jul 22, 2008 | Lands Phones
Pocket PC e400 en Sandisk WiFi
I have bought the Bluetooth Option Part for my e400. It was an "PC Bluetooth SD Card2". In the specs of the Bluetooth Card is an SD/IO enabled SD Slot required for the Card. So I think your Wifi will also work.
Sep 11, 2005 | Toshiba e400 Pocket PC
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
