Question about Balboa Instruments Pool & Spa
Control pad does not work
Spa is running
    Champion:
  • 305 Answers
Replace control pad, otherwise prob is in the circuit board
Posted on Dec 05, 2013
The off button on my Pentair MasterTemp 400 pool heater does not shut if off. All the other button controls work. What is wrong?
You need to replace the "membrane pad". The pad is separate from the control board. Sort of like a keyboard on a computer.
Jan 28, 2017 | Pentair Pool & Spa
What part needs to be replaced?
display board runs on 24 volts. make sure the secondary side of the transformer is putting out 24 volts. if the control pad is getting proper voltage and it doesn't work, replace the control pad and board
May 27, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Control panel not responding
Your spa side touch pad/ topside control panel is failing. It is only a "Communicator" the buttons are shorting between them. This is usually the problem when symptoms are manifest like yours.
Jan 26, 2014 | Dream Maker Spas Pool & Spa
How to use Sino Spa spa controller pad
controls operate the pump to circulate the water..there are controls for bubbles and an air pump to increase the volume of the bubbles..and a setting to run the tub slower to allow heating of the water..
Dec 18, 2013 | Pool & Spa
My raypac 2100 was working fine, recently replaced control pad. Today set heater to 90 it heated to 89 then pad read "off". Pad would not respond after that. Turned breaker off then on and error...
The EOL code means End Of Line. It means the heater has given up trying to run. There are a number of problems that could cause this issue. There could be no gas pressure, a defective gas valve, or something wrong with the control board, etc. To determine exactly what is wrong a person qualified to diagnose the problem will need to follow a diagnostics document from Paypak or call Paypak's technical support line. If you have a volt/ohm meter and have some debugging experience you might convince a tech support person to help you diagnose what the problem is. If you are not successful with that idea then you will need to find a pool equipment professional to do the job. I hope this helps.
Aug 22, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Why won't the spa jets turn on when I touch the touch pad? The light will not turn on and there is no response when I touch or push on the pad anywhere.
Do you have the operating instructions?
It may be that your topside controls are locked. Check your instruction manual, it should hopefully tell you how to unlock the controls.
Kind Regards,
Ian, from http://hottub.synthasite.com
Jun 07, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Savannah Spa Sunset Dlx control pad doesn't respond
What does it mean when the word SPA comes up on the control pad window and locking up the control pad.
May 23, 2010 | Aqua Pool & Spa
What is the freeze protection temp on a jacuzzi pump set at?
Pumps don't usually have freeze controls they will usually be in another control. Most are set at 38-40 degrees. All are different by brand but I think any run below 36. Be sure that your air temp sensor is OK if your having trouble, This will show on your control pad, and your temp sensor should be located below your control box by your equiptment. Hope this helps, good luck.
Dec 06, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Aug 26, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
One of two one touch control does'nt work
RESET TO FACTORY DEFAULTS(USE THE MASTER PANEL)THEN REPROGRAM YOU'R OPTIONS!!!!!!!!!!!!
Oct 23, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
56 people viewed this question
Top Balboa Instruments Pool & Spa Experts
russlakeside
Level 1 Expert
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
