Question about Poulan Garden
Poulan leaf blower want start searl ppb43ovs geting gas firing good and good compresion whats wrong
  • Ernest Singleton
    Ernest Singleton Nov 16, 2013
    my leaf blower ppb43ovs wont start getting gas firing good and good compresion whats wrong.
  • Ernest Singleton
    Ernest Singleton Nov 18, 2013
    was runing perfect shut it off a fue minutes during use and it failes to start back up
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
See if keyway on Flywheel is broken causing the Timing to be off.
Posted on Dec 29, 2013
4 Suggested Answers
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
bbreton
  • 437 Answers
SOURCE: mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Posted on Nov 02, 2009
Poula pro bvm200vs/ 25cc won't start
i have a polan bvm200vs. that wont starits got the main 3 gas spark and compresion i even change the gas in it and still noyhing
Oct 29, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Not getting gas, won't start. Fuel lines have been replaced. I think it might need a new primer pump???
check if there is a vacume line coming from bottom of cylinder on carb side and check filter in tank on end of lift pipe has it got good compresion prime bulb should lift fuel no problem unless it is drawing air
Oct 21, 2009 | Poulan Featherlite Gas Blower, with Low...
Blower will not start, will not fire
Doubtful. Clean the bolts and re-mount but I doubt that'll fix your problem. Check spark with an in-line spark checker. Be sure you have the right oil/gas mix...or you will burn it up. How did you check compression, what is the reading? Anything less than 100 means the piston ring is stuck.
Aug 15, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Have poulan pro gas blower,it is geting fire but will not start
spray carb cleaner in the carb with throttle at full then hold the throttle wide open for three pulls, if it doeasn't start remove air cleaner and put a finger over the carb hole and have an assistant or yourself pull the cord this may clear out the debree blocking the flow of gas otherwise the carb must be removed cleaned and the vacuum diaphram replaced.
Jul 15, 2009 | Poulan Featherlite Gas Blower, with Low...
GAS LEAF BLOWER WILL NOT START GETTING FIRE
Maybe your carb is out of adjustment. The easiest way to readjust is to turn the screws all the way in and start the blower. While it's running start to back the screws out until it runs nice and smooth and you should be all set.
Apr 30, 2009 | Garden
Poulan leaf blower wont start
try changing the spark plug. if that doesnt work let me know and i'll help you trouble shoot it.
Nov 02, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Stubborn Gas Blower
hey buddy chk that the cylinder head is loose or the gasket is blown,, thats what i found on mine after buying a new blower,, returned it no problem tho ,, you will have to manufacture a tool to tighten one of the bolts and also use locktite on the bolts so they wont backout after running ,, be sure to clean the holes and the bolts before applying locktite,, hope this helps ,,
bobby allison germantown tn
Oct 03, 2008 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
