Question about Mintek 10.2" mdp-1030 16:9 widescreen portable dvd player
Disk spining motor has gone bad needs to be replaced how do i do this
Disk does not spin player alwas diaplay's no disk in player even if i put one in it
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
After dvd shows to be loading, message says disk error. this happens on any dvd loaded. can not hear player operating. Can this unit be repaired?
I believe one of two things is the couse. First try to look inside to see the disc spin or listen for the hum of the disc spining; drive motor may have failed.(not hard to fix if you can find a motor online) Second and a much easier fix if the motor is spinning,is to disassemble the cabinet and clean the lense with a Q-tip carefully.
Mar 29, 2011 | Samsung HT-Z210 Theater System
The portable dvd player isn't spinning the disc and it isn't reading the disk it comes up with saying no disc even when there is a disc in the player
it could be that when you close the lid it does not press the switch that start the motor. <br /> if you see the disc spining maybe the laser head is not clean <br /> or the main board is broken <br /> If you want to fix the portable DVD write to me , <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Aug 26, 2010 | Sony DVP-FX810 Portable DVD Player
Turns on, but will not play or recognize DVD
The spindle motor motor is defecteive already. replace it. when the spindle motor not working. the cd wont spin, how can the optical lens read the disc when its is not spining. you need a qualified technician to fix your problem.
Jun 27, 2010 | Insignia IS-PDO40922 Portable DVD Player
Disk not spinning
need to replace the spindle motor.
Aug 28, 2009 | Insignia IS-PDVD10 Portable DVD Player
No disk
The drive motor may be bad and the disk is not spinning up or the laser is probably bad and it is not reading the disk.
You may also want to make sure that the disk is firmly on the spindle. The Durabrand players have a stiff spindle and you have to press firmly till it clicks in or it won't spin up, causing the error.
Cheers
Jan 03, 2009 | Durabrand DVD-1002 DVD Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Bad Disk
If you find that the DVD is not spinning it might means that the the "spinner" is not functioning, the sound you hear is the laser moving up and down trying to read your DVD but since is not spinning it can not read it. You will need to replace the small motor that operates the spinner, after extensive use they just give up. I hope this is helpful enough.
Aug 30, 2007 | Polaroid PDM-0082 Portable DVD Player
"loading" then "no disk"
You might as well just replace the player, the cost to repair is more than a new one.
May 18, 2017 | Coby DVD-218 DVD Player
Mintek 10.2" mdp-1030 16:9 widescreen portable dvd player Logo
15 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
