Question about Motorsports
Wipers blades does a 88 chevy van have a pulse board module cant locate.wipers move slow and weak and sometimes just stop
Hi! Possibly a worn wiper motor assembly, the board is inside the wiper motor unit..
Posted on Nov 16, 2013
2009 toyota corolla/ windshield wipers stop working on intermittent setting. have to push on blades to start moving again. is it relay, motor, switch?
hi there . think they may need a bit of wd40. spraying on the shaft.
probably just road dust and debris. making it stick.
Mar 01, 2014 | 2009 Toyota Corolla
Wipers don't touch windshield
The wiper arm springs are weak,just grab a used set of arms as most ventures wipe great.People who stick their wipers straight up,usually when freezing rain is coming ,ruin their wiper arm springs and have less wiping pressure too, so have to replace their arms at some point. PEOPLE STOP LEAVING YOUR ARMS IN THE UP IN THE AIR,OFF THE GLASS POSITION.
Mar 10, 2017 | 2001 Chevrolet Venture
Sometimes my windshield wipers work and sometimes they won't on my 1994 chevy lumina van. I tried bypassing the switch but It won't do anything. What is the problem?
This is a common GM problem. The issue lies in the control module which is the black cover on the driver's side of the firewall under the hood. The replacement kit for these run between $35 and $55 depending on where you purchase them. the remanufactured units are just as good. They come with 3 new Torx head screws, the circuit/relay board, di electric grease for the connector and a new cover. Takes about 3 minutes to change. A1 Cardone 81158PB Remanufactured Wiper Motor Pulse Board Module
May 15, 2011 | Chevrolet Lumina APV Cars & Trucks
Wipers intermittent... sometimes they will not start untill the wiper motor, under the hood is hit whith palm of hand, sometimes rotating wiper control switch/curse control switch/washer button is pressed....
sounds like the wiper motor,module is bad thats what controls the wipers on where to stop and all that stuff,replace the wiper motor and youll be ok
Oct 13, 2009 | 1999 Chevrolet Suburban
Wipers wont trun on
add a ground wire to the side of the wipermotor on the side with no rubber mounts.
Jul 05, 2009 | 1998 Chevrolet Blazer
Windshield wipers will not turn off - 2003 Chevrolet Silverado
Fixed the wiper problem which was identical to Brad's by changing out the wiper module which is also called a pulse module or something of that nature. Pretty easy fix. You have to remove the grill that the wiper blades protrudes from in order to get to the motor (4 clips in front which can be removed by hand, remove radio antenna, a center push down retainer, two plastic end caps which pop off and then 1 star type screw on each end under the end caps). Getting the blades off seemed difficult. I used a small puller to pop them off after removing the nuts.
You can't buy this module at a regular parts store. I had to get it from the dealer so be prepared to spend $130 to $140 for the part or go to the salvage yard. Works great now.
Mar 14, 2009 | 2003 Chevrolet Silverado 1500
Wipers stop after 5 minutes of slow or intermiant speed use.
Try replacing the Wiper Motor Pulse Board Module. It is available at aftermarket parts stores, it is easy to replace, and it is a high failure item. Eventually, the module will fail completely and leave you with no wipers.
Feb 25, 2009 | 2001 Oldsmobile Intrigue
Winhshield wipers do not work
How do I replace the radiator on a 1998 4.3L chey Astro Van?
Oct 01, 2008 | 1998 Chevrolet Astro
Motorsports Logo
109 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Trp Nap
Trp Nap
Level 1 Expert
Are you a Motorsport Expert? Answer questions, earn points and help others
