Question about Intermatic KM2ST-1G - 24 Hr. In-Wall Electromechanical Timer - SPST - Whit
Won't shut off
Runs continuously in all modes
  • Intermatic Master
  • 5,089 Answers
Timer comes with 1 year warranty:
KM-series dial should rotate continuously, no matter which mode.
Is this new timer? Maybe wiring is wrong
http://waterheatertimer.org/How-to-wire-timers.html
Buy another timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#KM
Gene
h
Posted on Nov 17, 2013
Testimonial: "Timer is three years old and functioned normally until recently."
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
Apr 12, 2013 | Water Pik Aqualink Rs4 Package - Pool and...
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
2000 gmc jimmy starts in AM fine won't start after sitting in sun all day
Can you jumper the fuel pump and make it start and continue to run ?
Have you checked to see if you are getting spark when it won't start ?
Could be a relay or coil, ignition module, or other component.
Aug 08, 2012 | 2000 GMC Jimmy
When the humidity set point is reached, the compressor shuts off but the fan continues to run. Is this normal?
Chucke - Depending on which mode you're operating the unit in (Continual Mode), yes that is normal.The fan continues to run in an effort to recirculate the air. If it senses a rise in humidity above the level you have it set on, the compressor will turn and remove that humidity.
Hope this helped you.
Jun 27, 2011 | Frigidaire Dehumidifiers
Does the fan shut off once the air conditioner reaches the temperature selected by the owner or does it continuously run when the air conditioner is on?
If this is a multifunction unit (AC/Dehumidifier) and you have it set on Dehumidify Mode as well as AC, yes , it will continue to run. If you don't have unit like this, but maybe have an economy mode, it will continue to run for awhile too. If you have neither, then no, it should stop running soon after the compressor turns OFF.
Jun 22, 2011 | DeLonghi Heating & Cooling
Does the fan on a Kenmore dehumidifier run continuously, or does it shut off when the set point is reached? I returned a Frigidaire unit because the fan is designed to run continuously.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Kenmore 54501 Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Jun 06, 2011 | Danby Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
Intermatic KM2ST-1G - 24 Hr. In-Wall Electromechanical Timer - SPST - Whit Logo
42 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
