Question about Frigidaire GLTF2940ES Front Load Washer
DRAWER OPEN MAGNET ON GLTF2940ES1 ?
WHERE IS THE DRAWER MAGNET ON THE SOAP DISPENSE DRAWER
    Problem Solver:
  • 10 Answers
Pull the drawer out and find it with a paperclip.
Posted on Nov 17, 2013
Soap dispenser will not stay closed\
    Good Morning D, thank you for your post!
    I understand the soap dispenser is not closing properly. There is a simple troubleshooting test you can do to see if you can remedy the situation.
  • ·If you've double-checked the drawer and it appears to be closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
  • ·If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
  • Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your washer.
Feb 19, 2014 | Electrolux EW1000i Front Load Washer
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer is leaking from dispense drawer, cleaned entire drawer thoroughly and still leaking
Remove the soap drawer and look for a sock or other item that might have gotten stuck in the hose
Nov 05, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is giving error code e10 and im not sure what to do my washer is a frigidaire front load
I have an error code chart that came with mine and it says a few different things for E10. 1st says water not entering washer. 2nd says water leaks. 3rd soap dispenser drawer is open. In another post there was something about a magnet needed in the drawer too. But I would suggest checking your hoses and making sure you have water and the drawer is completly closed.
Jan 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Buzzing sound then "ddo" flashes on panel
Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps
Aug 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Ddo error code
ok, I got mine to work. Push the button down on the back side of the soap dispenser that says push down or push here (to take the tray out). When you have it out you will want to turn it over and there are 3 or 4 white tabs. You will want to pop the front part of the drawer off and then on the bottom about an inch in/down there is a small slot to put it into. It is the same size as the magnet and the magnet goes with the squares on the top and bottom. You cannot actually see the magnet when the drawer is put back together. When I talked to the service man he said they did away with the magnet on the new model. How stupid to put it there to begin with!! Hope that helps and if it doesn't ask again.
Apr 14, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
