Question about Samsung HL67A750 67 in. TV
White dots onscreen on Samsung HL67A750A1F
White dots appear on screen, more visible when screen is black
  • 1779 Answers
SOURCE: white dots on sumsung plasma tv
This is a problem is usually on your Y sustain board. There are two adjustments for this in which an Oscilloscope is nessesary for the alignment. However, there are two other things that can cause this also. This is beyond your abilities if your not a tech. Sorry for the news, It's not a major repair but should be done by a qualified tech.
Posted on Mar 17, 2008
  • 184 Answers
SOURCE: Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Posted on Feb 14, 2009
  • 5 Answers
SOURCE: white dots appeare on my Samsung LCD screan
Sounds like your panel is on its last legs so to speak.
Might be time to look into replacing the panel. Running a high contrast can lead to a shorter panel life which may cause the occurence of dead pixels.
Posted on Mar 20, 2009
  • 668 Answers
SOURCE: i have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Posted on Jul 18, 2009
SOURCE: white dots all over screen
this seems to be an issue either with your DMD board or with your Digital Video board... turn on the tv and go to the menu if the white dots appear on the menu the issue is with your DMD board but if they don't show on the menu, the issue would most probbaly be with your Digital Video board
Posted on Jul 23, 2009
Blank screen, led lights flashes for a while and thn all three flash. also cannot turn off at tv or with remote. have to unplug
Samsung HL67A750A1F red DLP LED failure repair ...
? 10:35
https://www.youtube.com/watch?v=xHE1knzJSfQ
Jul 21, 2011 - Uploaded by daveshelbygt
Samsung PHLA... ... Samsung HL67A750A1F red DLP LED failure repair .... tv only works when plugged in. black screen, any suggestions?.
HL67A750A1F Blank Screen, And The LED Lights Are On ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 24, 2011 - Click here if the screen is blank and one or more of the LED lights on the front of the TV are on or are flashing.
Samsung HL67A750A1FXZA Repair Success Stories ...
Jan 19, 2016 | Samsung HL67A750 67 in. TV
White screen
"White screen" on Samsung LED TV - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from www.cnet.com
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
Three small white dots have appeared on the screen. What does it mean, is the lamp going bad?
White dots are caused by the DLP chip failing.This part must be replaced to get rid of the white dots. Samsung is covering the cost to repair this problem on several models. Ypu can call 1-800-samsung to find if your unit is covered.
Oct 06, 2010 | Samsung HLN617W 61" Rear Projection HDTV
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Spots on screen, looks like stars. cleaned lens, what else?
your dlp is is failing and needs to be replaced. it usually starts as one or two and continues to grow sometimes appears as white dots sometimes black dots
Jan 23, 2010 | Samsung HLM507W 50" Rear Projection HDTV
your dmd chip is defect this a good job you must tack emgine apart calculate atleast 200 dollars
Dec 06, 2008 | Samsung DLP HL-P5663W 56" TV
White dots appearing on tv screen
Will need model number, but sounds like digi board problem
Craig www.classtorations.com
Mar 18, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung HL67A750 67 in. TV Logo
106 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
