Question about Mintek MDP-1770 Portable DVD Player
Disc not spinning motor - Mintek MDP-1770 Portable DVD Player
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
Dec 19, 2011 | Sony Audio Players & Recorders
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
Dec 05, 2009 | Sony DAV-DZ100 System
After loading a disc it says "no disc"
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Aug 25, 2009 | Durabrand DUR7 Portable DVD Player
Disc won't spin so I can't play the game/DVD/CD
replace the motor. The motor has burned out causing the disc not to spin.
Jan 20, 2009 | Sony PlayStation 2 (PS2) Console
The spin motor doesn't turn spin the disc
yes you can replace your lens also your lens is not working so you have to change
May 18, 2017 | Philips DVP5960/37
Mintek MDP-1770 Portable DVD Player Logo
23 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
