Question about TitanNet Vaper 41181 90 Amplifier Wire Feed Welder
How do you rewwire a vapor 90 amp welder - TitanNet Vaper 41181 90 Amplifier Wire Feed Welder
My welder is not sparking strong enought to weld I raise the amp all the way and it is not sparking like it should what could be the problem
make sure there is nothing getting in the way of the current flowing through the ground. slow down and keep the arc close to your metal.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I will make about 12 3" passes over 3" square
Nothing's wrong with your gun or machine. Your unit has a duty cycle of 20 percent at 90 amps, meaning that it will work (weld) great for 2 straight minutes and then it needs to cool down for 8 minutes. The duty cycle it is measure in 10 minutes lapses.
All you need to do is to let it cool down, and start again. That's all.
Jan 19, 2011 | Hobart Handler 140 Mig Welder
Kende 150R gas/nogas mig welder
Hi I have the same welder with the same problem, I've striped it down and found that there are a few teeth missing on the gears that run the wire feed,
Had no luck finding any replacement parts though
Sep 05, 2010 | Troy MIG100 90-Amp. Wire Feed Welder
Clarke pro 90 gas mig welder wont penetrate
I have the same problem, please that´s some one knows how to fix this?
Apr 19, 2010 | Clarke Power Products WE6480 MIG95 Flux...
I have a miller 90 amp firefly xl when i'm
  • You can try changing the tip,
  • keeping your arc length shorter - closer to the weldment.
  • if your machine has a burn back function, set that to the correct setting, it may be set to something by default,or have moved (not available on all machines).
  • check your ground clamp - make sure it is clean and securely connected.
Apr 19, 2010 | Welding Tools
Does anyone know where I can find a how to manual for a wire feed welder? The only info I have is Pow R Mate 90 amp 120 volt model number 117021. I think they were made by century welders.
There a hundreds of books published on the subject, if you live in the USA contact Hobart, lincoln, Esab, all publish books and manuals.
Nov 09, 2009 | Welding Tools
I brown wire came loose and i have no idea where
You can obtain a schematic of the wiring from the manufacturer.. or try www.retrevo.com....
Aug 06, 2009 | TitanNet Vaper 41181 90 Amplifier Wire...
Mig welder tripping power supply
the breaker could be bad. try to change the breaker
Dec 09, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Suggested oxygen pressure
first of all good luck welding aluminium with a mig no disrespect intended but your gas pressure with change depending on the place you will be welding at 20psi is a good starting point
Oct 03, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
TitanNet Vaper 41181 90 Amplifier Wire Feed Welder Logo
57 people viewed this question
Top TitanNet Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a TitanNet Air Tool and Compressor Expert? Answer questions, earn points and help others
