Onkyo t-4500 memory loss
Loss of tuner memory
2 Suggested Answers
SOURCE: Onkyo T-4500 FM reception problem
I have the same tuner...yes the fm and am frequencies are different there than north america...check to see if you have the "worldwide" model...there is a small switch under a small hole underneath the tuner to select the region for where it is to be used. If its not the worldwide model then i think your outta luck.
Posted on Jun 01, 2010
Hi, I have the Onkyo HT R230 Integrated Amp/Tuner, Onkyo EQ15 Equalizer. How do I play the Tuner thru the Equalizer
I don't think you can. You can run any other component thru the eq first then to the amp but not the tuner.
Feb 17, 2017 | Onkyo Audio Players & Recorders
Can I connect a tv antenna to an onkyo HT R-550 receiver? I see only fm and am. Thanks.
Hi Mark, You can't connect a TV antenna to our receivers they do not have TV tuners. Thank you, Onkyo USA
Oct 21, 2016 | Onkyo Audio Players & Recorders
TV will not change or show channels
You don't say whether you have had it working at that location before. When you move a TV between houses, it is necessary to retune your channels. Would recommend returning to first time installation.
If you haven't moved it recently there are other reasons why this might happen. 1) There is damage to your aerial caused by weather, 2) A power surge or loss of power to the memory battery on your video board has wiped the frequency information from the memory [the memory battery is like a watch battery that keeps a small amount of power going through the system to it can keep your settings when unplugged], 3) The internal tuner board for your TV has packed in.
If '1' is the case, obviously you need your aerial fixed; if '2' is the case you need to retune again [you'll know if the battery is dead if you have to retune every time you turn on the TV]; if '3' is the case you either need a replacement AV board or someone to solder a replacement tuner board to it.
Jun 17, 2013 | Philips Phillips 40 in. LCD HDTV
Onkyo sr600 memory problem
I had the same problem with my TX-SR601 receiver.
Solution: I changed the capacitor C766 (100uF/6,3V) on the "DSP and main microprocessor" or "U1" board. This capacitor is responsible to keep the settings in the memory. It is directly next to the SRAM ICs (Q705-706) (type: CY7C1019BV/CV33-15VCT).
Now the receiver works properly again.
Mar 04, 2012 | Onkyo TX-SR601 Receiver
I have a 26" SANYO
problem vith tuner or tuner power or bad contact vith signal area or cable
Mar 26, 2011 | Televison & Video
67 people viewed this question
 Grubhead
Grubhead
