Question about Coleman York Control Board 03101237000 031-01237-000
My fan will not stop running and my pilot will not light on my DAYA-F030N070 Colman furnace.I have replaced the igenighter rod and the smart valve but it still will not light and the fan will not shut off. Help.
    Master:
  • 613 Answers
The inducer draft motor has to run and develop the proper amount of negative pressure (checked with a monometer) to close the pressure switch before anything else happens. Even if the pressure switch closed and the igniter energized, the gas valve wouldn't function until the flame is proven by a flame rod or rectification. The fan continues to run (inducer draft motor) because it is still trying to light. Call a qualified tech before you kill yourself or others
Posted on Dec 08, 2013
2 Suggested Answers
  • 13 Answers
SOURCE: I have a EVCON furnace DGAT070BDC. I replace the
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Posted on Oct 24, 2009
How do I light pilot light?
There should not be a pilot on a direct vent furnace. When you turn up the thermostat for heat the 1st thing to happen is a venter motor should start, it should vent for approximately 45 seconds, the air switch will verify a vacuum in the burner box, then a spark igniter should start clicking to start the pilot, then the flame rod will verify the pilot, the igniter will stop clicking, and the main burner will ignite and remain on until the thermostat has satisfied the set point. These guideline steps must be satisfied before the controller advances to the next step. The 1st step is the venter motor running, sometimes the motor will stick over the summer months, spin it manually to unstick it. PS, nothing runs if the fan door cover is open, as that shuts down the power to the whole furnace.
Oct 02, 2015 | Coleman Gas Fired Mobile Home Furnace,...
Colman gas furnace wont light
Is it natural gas or propane? If propane, make sure you are not out of gas. Does it have electronic ignition or a manual pilot? if pilot, make sure the pilot flame is still lit and the control knob is turned to the "On" position. If it has electronic ignition, shut off the power to the furnace and then turn it back on and see if resets and lights.
Feb 16, 2015 | Coleman 7990-319p Evcon Gas Furnace...
Smart gas valve get 24v. but pilot will not spark or light
Do you have 24 volts at the gas valve terminals when the pressure switch closes?
Dec 17, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Pilot runs gas valve clicks but no ignition dayton 3e226c
There is a small Allen head screw in the gas valve that can be removed to test for gas after the gas valve. When the gas valve opens, gas should be present at that port. If none, you have a bad gas valve. If you gas gas, then there must be a restriction at the main burner.
Jan 21, 2011 | Dayton Gas Furnace Heater
We have a Colman Direct Vent Forced Air furnace, Model 7970A856, in our mobile home. We just moved in. We cannot get the pilot to light.
thermocouple is bad, thats the little probe that sits in the pilot flame, and runs back to the gas valve
Oct 23, 2010 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
My Ruud Furnace wont stay lit
Hi Bmreid
The problem you describe sounds pretty much like your gas valve is going bad. There is a brand by Honeywell called a Smart Valve which is anything but smart, when the electronics in the valve start going bad the furnace will run great for a day or two and then the next day may not run at all and then an hour later my run and then an hour later may not run again. Very sporadic operating furnace is usually the Honeywell Smart gas valve going bad.
Nov 15, 2008 | Kitchen Appliances - Others
Open Questions:
See all Coleman York Control Board 03101237000 Questions
Coleman York Control Board 03101237000 031-01237-000 Logo
100 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
