Question about Hardware & Accessories
Hager eh-011 wiring for lighting
3 Suggested Answers
SOURCE: i have a hager eh
Here's the EH135 manual
http://waterheatertimer.org/Hagar135-manual.PDF
EH135 is 240V SPST timer with NO normally open pole and NC normally closed pole. Clock motor is 240V. Manual override located lower right of dial.
Tabs on dial push down and out. The manual seems to illustrate the following: tabs are down and out, timer is off and NC poles 5-6 are connected. When tabs are up, timer turns on and NO poles 5-4 are connected.
Posted on Sep 24, 2010
SOURCE: How to set Hager timer
Hagar EH711 is surface-mount analog timer with segments located around timer dial.
Timer has 2-position slide switch with I and O.
Timer has NO and NC wiring terminals, and I O switch reverses terminals.
Timer dial can be rotated by moving minute hand clockwise with finger
Open following link for instructions that illustrate how to set analog timers by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
Open following link to see Hagar analog and digital timers with illustrations and manuals:
http://waterheatertimer.org/Hagar-timers-and-manuals.html#700-series
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 07, 2011
I am fitting a hager ez003 timer to our board does it need an earth as when we took off the old timer there was an earth fitted we are fitting it through an hager es 420
Wiring diagram for EZ420 delay timer does not show ground or earth connection.
It shows 12-230 volt AC Hot and Neutral, or 12-48 volt DC +-.
I assume the body of the timer is plastic/ cannot be taken apart/ has recessed screws and terminals/ and is double-insulated? Making ground or earth unnecessary.
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/pdf/EZN003_delay-timer-User_Instruction.pdf
Gene
Water Heater Timers Save Money
Aug 04, 2015 | Hardware & Accessories
Do I need to fix the board earth wire to the hager es 420 as I'm reinstalling a ez.003 to the board
basically if there is an earth point available and and earth wire provided then for safety sake it should be connected
when in doubt discuss the situation with an electrician
Hager timer switch wiring diagram
Copy following link for Hagar timer wiring diagrams and to identify timer model:
Gene
Jul 31, 2013 | Hardware & Accessories
How can i connect a timer switch hager EH 010 to three phase DOL startor. the startor is using for 7.5 HP motor
Copy following links for installations:
http://waterheatertimer.org/How-to-program-Hagar-timer.html#wire
http://waterheatertimer.org/images/EH-010-timer-wiring2.jpg
http://waterheatertimer.org/images/EH-010-timer-wiring.jpg
http://waterheatertimer.org/How-to-install-3-phase-timer.html
EH 010 timer is rated 16 amp max.
Typically this timer is connected to 12-14 gauge wire
Typical 3-phase 7.5 Hp motor draws 22 amps at 230volt and probably connected to 30-40 amp breaker and size 10-6 wire.
Timer and wire to timer must be fuse-protected with 15a bus fuse or line fuse or fuse block, and cannot be directly connected to 30-40 amp line.
Add comment as needed.
Apr 18, 2013 | Hardware & Accessories
How can i connect a hager EH010 timer switch for DOL startor. the startor is using for 7.5 HP motor
Hello sajikumar
Following links have wiring illustrations:
The EH 010 timer has max amp rating 16 amp max.
This timer is connected to 12-14 gauge wire
Ordinary 3-phase 7.5 Hp motor draws 22 amps at 230volt and probably connected to 30-40 amp breaker and size 10-6 wire.
Timer and wire to timer must be fuse-protected, and cannot be directly connected to 30-40 amp line.
Add comment for more assistance.
How to set Hager timer EH 711 from 7pm to 11pm
Sep 07, 2011 | Hardware & Accessories
I have a hager eh 110 time switch on my pool and I cant set it. Any clues?
Hagar EH 10 is 230V analog time switch.
EH010 is 1" wide.
1) See large image of EH010
http://www.bewdirect.co.uk/home/m/Shop/id/3985/page/1/
2) See large image that explains how to set EH-010
http://waterheatertimer.org/images/EH-010-image-1000.jpg
3) With analog timers, there is a movable dial that rotates with fingers.
Pins or segments are located around edge of dial.
Segments are moved one direction or the other to set on-off times.
After segments are set, the dial is rotated to match current time.
The dial rotates as time passes, and segments move a switch that opens and closes electric circuit.
4) EH-010 is different.
Usually analog dial is located on face of timer like a clock face.
However EH-010 is only 1" wide, so dial is perpendicular to front of timer and is rotated with thumb.
5) I suggest setting a few segments one direction or the other and then manually rotate dial full circle to watch when pool equipment turns on-off.
This will tell you if segments should be set right or left.
I have not seen this particular timer, but it appears as if times on printed on edge of timer dial.
6) Timer has 240V clock motor.
So Hot line wires from circuit breaker connect to terminals 1 and 2.
This powers clock motor so dial rotates as time passes.
240V Line and 240V Load wires are connected as shown in image below:
Feb 10, 2011 | Electrical Supplies
I have a hager eh 135 timer & don't understand how to set it.My email adress is. brenton.1955@hotmail .com
Sep 23, 2010 | Hardware & Accessories
Cleaned oven now door will not unlock
Turn off the breaker for a few minites, turn back on,check it. If still locked use a wire hager and flashlight to push the lever of the lock to the open position. You'll need to replace the door locking mechinisum about 30.00.
Mar 12, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Hardware & Accessories Logo
42 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
