Question about Kenmore Ovens
8272851 need replacement glass top
The glass top on my format oven has a crack in it, can i replace the glass top?
Yes it can be replaced and without to much hassle just a few screws. Finding your glass from your manufacturer would be where i would start first, locating the glass is why most people have to purchase a new stove because parts are not available. Please rate my solution it is how i earn my achievements. Thanks in advance
Apr 13, 2012 | Ovens
Schott ceran cooktop glass replacement
Hi, cooktop glass replacement can be found at amazon, here: Amazon com Schott ceran glass take a look. Wish you best of luck
Mar 31, 2012 | Belling Ovens
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
The Schott glass top is cracked - where can I replace it?
I will assume you are talking about the glass top on a range..If so they are not cheap..they range from 600.00 to 1,000 for a replacement top.
Dec 19, 2010 | Whirlpool Ovens
Glass top broken,can it be fixed
The glass top can be fixed. You will need to call a parts dealer to order. They usually run a couple hundred dollars. If you are going to replace yourself than you will need to pull the stove out and disconnect power. Than remove the side panels and it allows access to the screws holding the glass top in place. Be extremely careful when replacing these. They can break easily. Make sure you place burners and everything on the new one exactly how they are on the old one. Easy way of doing this is have a couple big towels and set next to each other and switch parts there. Remember that when you put it back together to clean it with glasstop cleaner before you use the stove.
Jun 13, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Replacing a glass cook top
I have the replacement cook top that you need (part #WB56T10165). I work for a GE Appliance distributor and will sell you the part for WAY less than list price. The item is an unopened, genuine GE replacement part.
Let me know if you're interested.
Jan 09, 2008 | Ovens
Top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
