Question about Sewing Machines
I have a singer 7422 and it will not see zigzag pattern even when it makes motion but only picks up on right side and makes straight stitch?
  • Sewing Machines Master
  • 7,365 Answers
A gear or cam could be broken or worn, the machine needs to be checked at a sewing machine shop
Posted on Nov 16, 2013
SOURCE: Will not zigzag
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Posted on Oct 17, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
Maggie_B
  • 3 Answers
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Posted on Oct 31, 2009
Why are some of the pattern lights green and some green on the singer model #9217
It generally means that your machine cannot do that stitch with its present settings. I took a look at your manual, and it lists the stitches and what they're for. They also mention that your needle must be in the center position for any zigzag stitches; you can only position the needle to the right or left when you're straight stitching. If you do not have your manual, you can download one free at the Singer sewing machine site.
Jan 09, 2015 | Singer Sewing Machines
I cannot get tight tension on zigzag underneath stitch on my singer 3221
There are a couple of things to check. First, did you thread with the presser foot UP, so that proper tension is applied to the upper thread? Is your bobbin correctly inserted, and is your bobbin case inserted evenly and correctly? Review your user's manual--if you don't have it, you can download it free at the Singer website.
If you have done these things, you may need to adjust your bobbin tension. First, run a line of straight and then zigzag stitches on a scrap of fabric and take a look. It helps to have two different colors of thread, with the fabric a third color. If one side of the zigzag looks fine and the other side looks like "chicken tracks," the chicken tracks side is too tight. In other words, you need to determine whether your bobbin tension needs to be tighter or looser.
You'll need a very tiny straight-slot screwdriver. Remove the needle plate--there are two screws in it--and remove the bobbin and then the bobbin case. On the side, there are two tiny screws. One is a Phillips--leave that one alone. The other is a straight-screw, and that one regulates the bobbin tension. The rule is "righty-tighty, lefty-loosey." Only turn it 1/4 turn, then reinsert and test. If you're on the right track, you should see at least a LITTLE improvement. DON'T do any more than that--if you don't do this carefully and systematically, you'll make things worse instead of better!
Jun 10, 2014 | Singer 2263 Mechanical Sewing Machine
Only half a stitch
Most likely, your hook timing needs to be adjusted. I'm afraid that this requires a technician, HOWEVER any sewing machine technician can adjust the timing, it's not machine specific.
Dec 31, 2013 | Singer 7422
Singer troubleshooting
It could be out of time. Try a new needle.
Nov 01, 2013 | Singer Sewing Machines
Singer curvy 8778 the needle is making the motions to stitch evenly, but the stiches to the left are missing, not the thread mind you. So a zigzag stich appears straight. I have done all the...
Call Singer at 1-800-4singer, sounds like a buttonhole lever problem. Is it like that on all styles of buttonholes? Check that out before you call them, and make sure that you pull the lever all the way down.
Apr 16, 2011 | Singer Curvy 8770 Electronic Sewing...
Will not zigzag
Oct 09, 2008 | Sewing Machines
BUTTONHOLES
Yes, If you have a zigzag function use that. First you must keep the zigzag function stationary then set it to about a one or two on the stitch dial. Try that!
Sep 21, 2008 | Singer 7422
Singer 5050 won't zigzag stitch
I have this same issue with that same machine. Did you ever figure out what was wrong with it??
May 08, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
