Question about HP Compaq Presario CQ57-229WM Notebook PC
Replace wireless network adapter - HP Compaq Presario CQ57-229WM Notebook PC
  • HP Master
  • 7,627 Answers
Perhaps this will help:
Posted on Nov 19, 2013
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
How do you install the wirleless router?
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3 Under or pick a Control Panel icon, click Network Connections.
4. Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
And Thanks.
Mar 18, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
On my wireless network adapter for the xbox the light is red
The adapter is inoperable. You'll have to send it in to Microsoft for replacement or get a new one.
Sep 22, 2009 | Microsoft Wireless Network Adapter Xbox...
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
TrueMobile won't connect to my network
Over the past few months I have seem more of this issue. I am beginning to think that there may be Microsoft updates that could be conflicting with the wireless network adapter config. But this is only a speculation.
In the mean time, you may have a faulty wireless card. If the unit is under warranty, have Dell replace it. If not, you could disable the internal one and purchase a Linksys Wireless G or N USB adapter from Staples....just to rule it out.
GB Plus -
Mar 13, 2009 | Dell TrueMobile 1180 802.11b Wireless...
Netgear router and microsoft adapter compatablity
You might try looking for updated drivers for your Microsoft adapter. Older wireless adapters often do not support newer wireless security methods like WPA/WPA2, so if your router is set to use something besides WEP, that may be the answer.
If you're not using wireless security and you still see intermittent connection issues, I'd consider using a different wireless adapter. In my experience, Microsoft wireless adapters do not have the range other brands do.
Jan 30, 2009 | Microsoft Wireless Network Adapter
Network card corrupted
If your network card is gone bad then replace with a working network card.
Dec 23, 2008 | Zonet Fast Ethernet Adapter Realtek 8139D...
Can't set up wireless connection
  1. Check in your system: Click Control Panel, then double click System. On the Hardware tab click Device Manager. Click the (+) sign besides the Network Adapter. See if the Packard bell wireless adaptor is there. If its is not there, right click the Network Adapter and click Scan for hardware changes, and reinstall the network adapter.
  2. If the Packard bell network adapter is already there, click Start and click My Network Places. On the left side of the Network Connection, click View Network Adapter. The wireless network adapter should be there. Right click the wireless network adapter and choose properties. Give check mark on Show icon in notification area when connected (to show you if there is wireless notification), and give check mark to Notify me when this connection has limited or no connectivity (to show if the wireless network is disconnected). and click OK
  3. Turn on the orange broadband livebox. And right click the the wireless network connection (on Network Connection) and choose View Available Wireless Networks. And the click the Orange broadband Livebox to use this wireless Network connection.
I hope this solution is helpful to solve your problems
Best Regards
Blackrobin
Nov 16, 2007 | Computers & Internet
HP Compaq Presario CQ57-229WM Notebook PC Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
