Question about Sewing Machines
Jcpenney model no. 6005
Thread keeps breaking on bottom lower thread
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
SOURCE: thread continually breaking in lower looper needle
I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
4-3-3-3 and default settings for the rest.
Hope this helps someone someday.
Jo Griffith
Posted on Mar 29, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
SOURCE: On my overlocker, the bottom two threads keep breaking.
globe overlocker stitching reverse
Posted on Jun 18, 2009
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
First Thread breaks on nelco 928 why?
Remove all the threads.
Replace the needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify each thread is in the correct thread path.
ALWAYS THREAD each in the order specified or you will continue to have problems--for a lot of machines, the order is Upper Looper, Lower Looper, then needles.
Check the tension on that particular thread--too tight, it will break.
Breaking thread after about an inch usually indicates it is mis-threaded--a guide has been skipped or threaded out of order or the thread may be wrapped around something.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Sew What Up View thread Help Needle thread keeps breaking
Nov 21, 2017 | Sewing Machines
Why does top thread keep breaking?
Sounds like your tensions, both upper and lower are out of whack. Easily fixed if so...google a vidyfor your make/model machine on adjusting both upper and lower tensions.
Jun 18, 2017 | Sewing Machines
Elna 6005 - I need to move the tension dial to 9 to get an even stitch. I re-treaded the machine and bobbin and it is still the same. Any solutions?
it is common when threading a machine for the top thread to get behind the tension plates and not between them
this makes it bind up on the mount bolt and gives false tension settings
even threads also depend on the bottom thread tension which is adjustable by the tiny screw that holds the spring clip that you pass the thread under when you put the bobbin back in the case
try going google --type in-- workshop manual for elna 6005 --and see if there is a pdf version available,
Sep 06, 2015 | Elna Sewing Machines
My lower looper thread keeps breaking. I rethread it, checked the tension and yet it still breaks.
Please re thread machine from scratch threading upper looper first then lower looper then needles also be sure needles are in with the flat back to the back of machine sequence of threading is imperative
Feb 24, 2015 | Euro-Pro Sewing Machines
Thread keeps breaking and underneath not sewing right
There may be a broken thread in the bobbin case effecting the lower thread tension. clean all parts and determine if the upper thread or lower thread is breaking if cleaning does not help. double check your machine threading and bobbin installation direction.
http://www.mastersewusa.com : this site has many operator manuals if the above suggestion does not help.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Why does the 4th thread keeps breaking on my serger? I've re-threadedi it a dozen times carefully following the diagram. What am I doing wrong?
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Jun 23, 2011 | Simplicity Sewing Machines
My elna 6005 keeps on stopping ande I get the message stop for safety purposes. I have just had my machine serviced and I really don't know what to do.
Something is not quite right. Double check everything...loose needle, plug ins, threading, bobbin area for loose threads, etc.
Keep in mind that you've jostled the machine moving it from the service to your home. It could be as simple as the bobbin race being out of alignment. If nothing you do works... take it back and give the the person who serviced it the "look." and make him/her fix it.
Mar 13, 2011 | Elna Heirloom Edition 6005
Kenmore serger 3/4D, bottom looper thread keeps breaking, can't see where to put the thread before the last lower looper thread hole
Try looking for a free download on wiki, manage my life, or just plain google with your model number, someone will have your answer. As a last resort try tias.com or retrevo, or just plain Kenmore.com customer support.
Aug 14, 2010 | Sewing Machines
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
