Question about Adobe Photoshop CS2 for PC
Activation code for tactics manager 1.6 - Adobe Photoshop CS2 for PC
I need product key for tactics manager 2.0
The product key came with your product probably on a certificate of authentication or a similar document. It will be clearly marked.
May 19, 2014 | Adobe Photoshop CS2 for PC
Tip
PSP ERROR CODE "8010850f"
How to fix error code "8010850f" on your PSP:
Error code "8010850f" sometimes appeared when you downloaded certain games on your PSP. It will requires you to activate the system to use the content and could only work when activated through PSN. Here are some tips and tricks on how to fix this error.
Option 1: Go to account management by signing in to PSN on your PSP. Once under account management go to activation/activate - games then activate the PSP.
Option 2: Connect your PSP to your PS3 using a USB. Then go to [Accountmanagement] - [activate/deactivate] - [PSP] - [games].
After you processed either of the 2 options you can now play your games with no interruption.
Hope it helps.
on Feb 21, 2011 | Video Game Consoles & Games
I need an Activation code for tactics manager 1.9
Download a program called craggle then type In the name of the program
Sep 17, 2013 | Cell Phones
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
Psp error code 8010850f when trying to play demo games
From TIPS section:
Hope it helps.
Jun 18, 2011 | Sony PSP (Piano Black)
Bmw code 29a8 power management failure and l cant understand the meaning
BMW outputs codes in Hex format. The tool then reads the code and it may translate it to its own format. Some 29A.. code definitions here:
29A0 Lambda Sensor Post Cat Bank 2 Signal
29A1 Lambda Sensor Post Cat Bank 2 Signal
29A2 Lambda Sensor Pre Cat Bank 2 Signal
29A3 Lambda Sensor Pre Cat Bank 2 Signal
29A4 Lambda Sensor Heater Pre Cat Bank 1 Activation
29A5 Lambda Sensor Heater Pre Cat Bank 2 Activation
29A6 Lambda Sensor Pre Cat Bank 1 Signal
29A7 Lambda Sensor Pre Cat Bank 1 Signal
29A8 Power Management Network Failure
29A9 Power Management Battery
29AB Torque Request via CAN
29AE Tank Cap
Code 29A8 i
t's a NETWORK management fault, related with tne main computer. Will need to visit BMW dealer to delete or reset it.
I hope helps with this.
Mar 18, 2011 | 2009 BMW 5 Series
Adobe Photoshop CS2 for PC Logo
204 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
