Remote wont turn on the aircon for Conia CA9001....have replaced batteries. We have 5 Conia aircons and the remotes only work on 1 unit
Conia CA9001
  • 90 Answers
It is necesary to work all the unit in same mode ,cool or heat ,or something too
Posted on Jan 13, 2014
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
SOURCE: MITSUBISHI ELECTRIC'S AIRCON REMOTE CONTROL ICON
lock out controllers
Posted on Oct 20, 2009
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
caroldon
  • 17130 Answers
SOURCE: Carrier Aircon WCARG010EE 1 HP
You must check if there is power to the fan to confirm if there is failure of the fan motor. Since the FR display indicates there is possibility that the power is initiating.
If the remote unit is not powered from the main unit then it is possible that the main control section must be checked for failure in the control unit.
Check for faulty wiring to the remote unit-or a break in the wiring from the main unit. Check the received voltages on the remote unit.
Posted on Dec 09, 2010
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
YKR-K/002E cant switch it off with remote?
Make sure the batteries in the remote are good. Reset the aircon and the remote and try again. If not working, need to be fixed.
There may be a switch around the outdoor unit of the aircond for switch off.
Feb 25, 2014 | Heating & Cooling
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
I have an split-type aircon (brand: Fukitsu) remote control AR-DL2. it has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift indoor unit cover and remove DC wire from display sensor. After 3 minutes again plug it and close the door. Now you try with your remote. If still problem, check your remote through cell phone camera by pressing any button in remote. If ultra light is visible thr' camera, remote is o.k. If remote is o.k, repair/replace PCB. Thanks.
Feb 09, 2011 | Heating & Cooling
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
