Question about Locks & Locksmithing
How to install a 1125- sp interlocking deadbolt?
    New Friend:
How do you reset a new combination for a Royal Traveller by Samsonite lugagge strap
Posted on Nov 17, 2013
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
Key will not come out in unlocked position
I presume you figured it out by now, but if the tailpiece is installed wrong in many deadbolts, the key won't come out in one position or the other. It's called a "timing" problem and the way to fix it is to take it off the door, turn the tailpiece a half circle and put it back on the door. Usually Kwikset locks are designed so you can't put it in the wrong way, but it can happen. (If it's not the timing problem, then the deadbolt unit is defective or broken. They are designed to fail in a way that keeps them locked, so this could be a sign that someone tried to break in, or that someone used the extended bolt as a way to stop the door from closing and it hit the door frame too hard.)
The best way to install a deadbolt lock without the instructions handy is to look at the "lazy" cam and see if there is a way to install it wrong and don't install it that way. Example: If there are 2 ways for the tailpiece to fit in the deadbolt unit when the deadbolt is retracted and only one way for the tailpiece to fit in when the deadbolt is extended, then install the lock with the deadbolt extended and you can't install it wrong.
Jan 05, 2014 | Kwikset Locks & Locksmithing
Lost keys what can i do?
hi,
if you have lost your key you can call your local locksmith and have them come out and re-key the lock or you can take the lock into the lock shop and they can make you a new key.
chris...
Sep 06, 2012 | First Watch Security Single Cylinder...
How do you remove and install a neutral safety switch for a 1993 mitsubishi Expo SP manual transmission?
I presume you mean the clutch interlock switch on the pedal assembly. There is no neutral safety switch for a manual transmission. The interlock switch requires the clutch to be pressed when starting.
The switch has two 12mm (or 14mm?) nuts to adjust the position of the switch. There's a wiring harness connector so the switch and short cable can be removed.
SD
Jun 09, 2011 | Mitsubishi Expo Cars & Trucks
My Kwikset Electronic Deadbolt is working in reverse. When I push the lock button it retracts the deadbolt. When I put in the access code it extends the deadbolt. What is wrong?
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Mar 05, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
Deadbolt wont unlock
Remove the deadbolt cover by removing the 2 screws. This will get you inside the deadbolt. Try using a screwdriver to pull it back. You may in the end have to break the unit in order to get it out and replace it. I have the same thing happen with a deadbolt. I ended up having to destroy the unit to get it out. You are going to replace it anyway so do whatever it takes to get it to unlock so you can then remove it from the door and install a new one. You do not want a deadbolt that will not unlock.
Jan 09, 2010 | Kwikset Brz Sgl Cyl Deadbolt
How do I unmount a schlage keyed deadbolt? There do not appear to be mounting screws on either side of the deadbolt housing.
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Sep 27, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Locks & Locksmithing Logo
73 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
