Question about Oster Toaster Oven Tssttvxldg
My oven shuts off and displays e1 - Oster Toaster Oven Tssttvxldg
Digital display breaking up
it happens commonly with LCD we can do nothing replace the display unit
Jun 10, 2015 | Breville The Smart Oven Convection Toaster...
The toaster says shut door and door is shut
The micro door switch is bad if you can not find one for your oven try one for a microwave oven it will worl
Jun 08, 2015 | Toaster Ovens
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Bravetti euro pro microwave convection oven stops working
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#7#ixzz2hPnOVle4
Oct 11, 2013 | Toaster Ovens
I have 4 1132 Lincoln electric ovens. The 3 r at
What is the actual temp of the oven? Not what the display says? If the conveyor running normal? If so you just need a display board. Depending on what temp is there are many possibilties after that.
Sep 30, 2013 | Lincoln 1132-000-U 61" Electric Conveyor...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Toaster Oven Repair
Toaster switch does not stay down. I have to hold the switch down to get toast. The heating element works fine as does the oven. Can we fix the switch? Or, do you know someone to whom we can send it for repair? Thanks!
Sheila Newton
Winston-Salem, NC
Aug 16, 2008 | Toaster Ovens
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Door
On my toaster oven, sometimes the plate at the bottom of it would get stuck when shutting because the arms it uses to close it weren't very good.
I had to push it in with my hand to get it closed. (make sure it's cool)
Jan 08, 2008 | Oster 6260 1500 Watts Toaster Oven with...
Oster Toaster Oven Tssttvxldg Logo
29 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Craig Butler
Craig Butler
john h
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
