Question about Miele Navitronic H4890B2 Electric Double Oven
Oven screen went blank. There is now way to turn on or off or get to settings
Hitting buttons and reading manual did not work
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Need to check power supply first
Posted on Nov 22, 2013
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
Self cleaning oven not working right
shut the power off and see if it resets.
Jan 09, 2008 | Ovens
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Ovens Logo
124 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
