Question about Samsung Dvd-V4600c Dvd/Vcr Combo Component Dvd Players
Need manual says disc cannot be played
Device says disc can't be played
Check the manual of device as to which type of discs it supports. Also the other check would be to check the device manual for the type of files it can play on a disc.
If the above options dont help, then try cleaning the device player head or else use another disc to play as this disc might have got corrupted.
Jul 12, 2015 | Samsung Televison & Video
It is not playing any dvd's. It says invalid or
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
1. Ensure the Easy Setup procedure has been completed on the BD player.
NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
2. Ensure the inserted disc is compatible with the BD player.
NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step.
NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
4. Use a soft cloth to clean the disc.
5. Examine the disc for any cracks or scratches that might be interfering with playback.
6. Attempt to play another disc.
NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
7. Remove the disc from the BD player.
8. Turn off the BD player.
9. Unplug the power cord of the BD player from the electrical outlet.
10. Let the player remain without power for 1 minute.
11. Plug the power cord back into the electrical outlet.
12. Turn on the BD player.
13. Insert the disc into the BD player.
14. Attempt to play the disc.
If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
Here is the link to download and install the Firmware update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS360
Select the correct Operating System and download the Firmware update.
Then follow the instruction on the same to install the update in the Player.
If the issue is not resolved even after installing the update, then Playe may require service.
Jul 21, 2010 | Sony BDP-S360 DVD Player
Plays some won't play others firmware is up to
Please check in the manual provided which regions disc your Blue ray disc player can play. Check the same region code at the back cover of the Blue Disc you want to play. If it is same there is no problem in playing but if it is other than the one your player can play, it won't read or play. Try to get Discs which have all regions marked on them
May 01, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
Dec 05, 2009 | Sony DAV-DZ100 System
LG DVB T HDD/DVD 197 won't play dvd's want error
http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
Oct 20, 2009 | Televison & Video
I puit in the cassette with 6 discs and try to play them. The disc player does not play the discs but changes from disc 1 through disc 6 and then sayts eject. Can it be something I can fix?
no you can't fix it because they will not sell repair manuals or parts to the public, u will need to have it serviced at a factory repair center.
Aug 26, 2009 | Car Audio & Video
Dvdr3576h will record on dvd+r but will not play on other devices
You will need to finalize the discs on the Philips. I know the manual says that +r may auto-finalize, but I found that finalization sometimes fails on the first attempt. Go into the menu for the Philips, and select the Edit Disc -> Finalize option. Once finalized, your disc should play in other players.
-Tha Mp3 Doctor
Nov 14, 2008 | Philips DVDR3576H DVD Recorder
Disk error message
In the manual there is a list of discs the unit wil play. On the last pages there is a quick reference. There are also region codes that need to be set. Maybe a power outage reset your settings. Also it would be good to know if this unit played disc previously, plays other disks? Or the discs play on other players. It could just be a dirt problem as well.
Manual is available here;
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
FORMATING
step 1 - place disc into unit
step 2 - unit will recognize disc
step 3 - unit will state this disc needs to be formated press play/pause button
step 4 - it will ask you to confirm formating press "yes" play/pause
hope this helps. you can get you manual out and on page 47 it gives you these instructions
Jan 26, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Will not play any DVD
I may have bad news for you. Here's my story with the PVD4744S.
I watched over an hour of a DVD-video disc one night, no problems. The next night, I played only the intro; then the DVD player gave a message, "This type of disc cannot be played. Please insert another disc." Thereafter, I couldn't play any of several DVDs.
The manual gives little help:
http://service.us.panasonic.com/OPERMANPDF/PVD4744.PDF
My disappointment is exacerbated by the declining availability of DVD/VHS players with an RF modulator. Maybe Panasonic should create a repair kit for aging devices.
Jun 29, 2007 | Panasonic PVD4744 DVD Player/VCR
Samsung Dvd-V4600c Dvd/Vcr Combo Component Dvd Players Logo
Henry  Thomas
Henry Thomas
