Question about Samsung HL-S5086W 50" HDTV
HL-S5086W turns itself off
TV turns on normally for 15-20 seconds then turns itself off. Then all 3 lights blink. I have replaced the power ballast and have bypassed temp sensor and lamp door switch, ruling those out as problems. Because the lamp lights up normally for 15-20 seconds, I didn't think the lamp was the problem. Is it still possible the lamp is defective?
  • JonG
    JonG Nov 30, 2013
    replaced bulb and tv works fine. thanks.
    Problem Solver:
  • 8 Answers
If your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Posted on Nov 29, 2013
SOURCE: Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
Posted on May 08, 2008
  • 1694 Answers
SOURCE: Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Posted on Jan 24, 2009
  • 184 Answers
SOURCE: hlp5063w 50'' projected samsung lamp won't come back on ?
It could be the lamp but don't overlook the lamp door interlock switch. If the lamp door is not aligned properly, you may have intermittent shutdown or no start conditions. You can temporarily cross the interlock switch to confirm that this is the cause.
michtech
Posted on Feb 17, 2009
  • 1039 Answers
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Posted on May 02, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
The Samsung HL-S5086W turns off after about 20 seconds. The Standby/Temp, Timer, & Lamp lights will blink simultaneously and then it shuts down. We blew it all out to clean the dust, removed the back...
Because the problem was the lamp. The unit will not power up unless the faulty lamp's replaced with new one. Click this LINK to buy online.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
Jdvillanueva
Jun 14, 2011 | Samsung HL-S5086W 50" HDTV
My tv will turn on and then shut off 10 seconds later. I've had this problem before and was able to turn the unit back on but now the three lights (lamp, timer, standby/temp) keep blinking so I can no...
Hello. First thing to do is to replace lamp in your TV.
Especially if it was not replaced for year or longer.
If problem continues - then professional should diagnose it and determine if ballast went bad as well.
Regards.
Russ.
Aug 11, 2010 | Samsung HL-S5086W 50" HDTV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Sep 28, 2008 | Samsung DLP HL-P5663W 56" TV
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 42 inch projection
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Feb 07, 2008 | Samsung HCN4226W 42" Rear Projection...
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
226 people viewed this question
Henry  Thomas
Henry Thomas
