Question about Mr Heater Base Camp Portable Big Buddy Heater
Dont work on hi
Works fine till I turn on hi then it acts like it starving for gas and goes out and ki have a filter its a new unit the filter to
I filled up with gas and my 95 Buick park avenue started to act like it was getting no gas after using about a fourth a tank.put different gas in and ran fine till used about fourth a tank again. Could it...
put in some gasline antifreez this will dissapate any water in the tank if this does not work start with a new fuel filter and then you might need a new fuel pump if problem gets worse as time goes by even a poorly sealing fuel cap can cause these kinds of problems
Nov 08, 2017 | Buick Cars & Trucks
My 2004 Honda civic won't start. It will start fine minute then I will run into the store and it won't start. It acts like it is starving for gas. If I wait a while it will start.
Check the fuel filter. Air cleaner. Vacuum lines and fuel pump. And all fuses. Make sure the gas cap is venting and dont trust the fuel gauge fill it up.
Aug 21, 2017 | Honda Cars & Trucks
My club car gas golf cart was running good then al the sudden wont go over idle speed
Perhaps it's a stuck carburetor float valve, bad fuel pump (if it has one) or clogged fuel filter.
Jul 03, 2015 | Cars & Trucks
Hi, I have a John Deere Z225 with an 18.5 Briggs
Although, this does sound like a fuel issue due to past experiences I want to say the problem might not be fuel at all, but before we go that route try one thing. On that particular model I believe the gas cap is vented, if so try running it till it acts up, then remove the gas cap for a moment and see if the engine returns to running normal, if not I believe your coil is going out. I have seen alot of these engines recently where the works fine but when the get hot they quit functioning all together or only function part of time which in your case would indicate why it is missing and fowling the plug. When these tend to do this after they cool back down they function properly again until they get heated up again. I hope this helps you.
Oct 03, 2013 | John Deere Garden
Car dies after it warms up, no pressure in radiator when i remove cap, and acts like it's starving for gas
Some of the information does not correlate.
If there is no Pressure, then you Radiator Cap is Bad
Stalling or Starving for Gas can be a Fuel Pump or Air Filter
Remove the Air Filter and see what happens.
Test the PRESSURE of the FUEL System
Apr 10, 2013 | 1993 Dodge Dynasty
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
1993 Jeep Grande Cherokee wants to stall
DONT BE CHEAP IF IT NEEDS IT DO IT JUST MY ADVICE JEEP ARE DIE HARD
Aug 23, 2009 | 1993 Jeep Grand Cherokee
STARVED FOR GAS
Hi, More than likely the jet in the carb is clogged.
This occurs when the fuel stays in the carb during the winter. Auto parts stores have a carb cleaner that should clean it out.
Hope this helps.
Kurt
Mar 25, 2009 | McCulloch 26cc Gas Blower Mcb3208
Mr Heater Base Camp Portable Big Buddy Heater Logo
205 people viewed this question
Top Mr Heater Base Camp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mr Heater Base Camp Audio Player and Recorder Expert? Answer questions, earn points and help others
