Question about Ultra Max Home
Trouble garage door
My neighbour has a ultra 03349 model garage auto door. The pulley on the motor drives when away from the belt pulley. But looks worn on its teeth. But when next to belt pulley it does nothing. Any ideas please
    Master:
  • 796 Answers
Disconnect the door so the belt and pulleys will run without a large weight to move. If they move ok, reattach the door and try again but help the door move with your hand. If it moves ok then, the door levers and joints may be too stiff and need lubicating and wiggling until they move freely.
Posted on Dec 15, 2013
I have an ET 500 gate motor. My neighbour's remote opens my gate as well when she opens her garage door. How can I change my ET receiver to prevent the neighbour opening my ET gate motor?
Most garage door openers and I assume gate actuators have jumpers or settings if computerized to change frequencies.
Both the remote and unit will have to be changed.
Larry
Aug 05, 2016 | Building Materials
Chamberlain - Garage Door Opener opens on its own
This may sound strange but it's true.....your neighbours TV/Stereo/video etc remote may be on the same frequency as your garage door...I swear I am not kidding.
Apr 08, 2017 | Building Materials
I installed the belt of the lift master garage door opener, but it looks like it has a lock and it does not open and close correctly. How can I re-set it?
The position of the belt and the limit assembly must be synchronized to operate properly. You need to loosen the belt enough to lift it from the pulley on top of the motor and then run the motor until it runs in the clockwise direction and stops. Now with the belt connected to the door and the door closed put the belt back on the pulley and tighten. Should do it.
Apr 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
Push the button i can hear the motor turn on but the door wont open
there mite be any thing struck in the motor belt or the pulley would be detached from the motor.. check for it......
Thanks for rating Good luck..
Jan 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener motor runs but the belt does not turn, any ideas?
I would get a ladder and take a look. Be careful, things are moving up there. Maybe the drive pulley/sprocket came loose from the shaft.
Dec 27, 2010 | liftmaster Chamberlain Garage Door Opener...
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: Hi, The belt that connects the motor to the pul...
IF IT IS ONE OF THE NEWER BELT DRIVE OPERATORS THE BELT ATTACHMENT IS ADJUSTABLE.
IF IT IS ONE OF THE VERY OLD OPERATORS AND YOU IN FACT HAVE THE CORRECT BELT YOU CAN NORMALLY SET THE BELT ON THE SMALL PULLY AND LAY IT AGAINST THE LARGE PULLY BY TURNING THE LARGE PULLY YOIU CAN ROLL IT ON.
May 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Have a Sears Opener 76LE that has operated without trouble for over 25 years. Yesterday, I tried to open door and as soon as unit was under load, went into the close mode, then tried to open, then closed....
If your opener is truly 25 years old there are not going to be any parts available. The model number you give is not the model number. It starts with 139. and probably has 6 numbers after the period or dash. Once you have it you can go to Sears parts and see if there are parts available.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Chamberlain Whisper Belt Drive
door does not close without holding wall button in
Oct 15, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Home Logo
Top Ultra Max Home Experts
john h
Tom Chichester
Are you an Ultra Max Home Expert? Answer questions, earn points and help others
